Buying a 350z - engine abuse....
ukrickk
Hi,
So hello :-)
i'm looking for a 350 - having finally decided to push the boat out :-) I've been lurking around the forum and researching for awhile, but one question that alludes me is... if you shouldn't run the 350 on 95 RON, and I'm buying say a 60k 350, is there anyway to tell if the engine's been run on 95 RON all it's life and is ready to pop? Is it just "listen for any knocking sounds" etc or are there key things I should look out for please?
Thanks for any help - looking forward to finally owning one of these lovely cars
Only way to tell really is a visual inspection of the piston faces, which can be done by endoscope. I had this dilemma when buying my car but I reasoned that as the engine hadn't gone pop yet, and wouldn't be subjected to any more knock from low octane fuel, it SHOULD be ok. But I also have a 'new bottom end' credit card on standby just in case, lol.
DB
wow - you're a nice bunch :-) and hello back! I think you're right, I shouldn't worry too much as I won't add to any further damage if any's been caused. I'll definitely ask the question, "is it right you have to run these on premium fuel, or does it not really matter?" and see what they say :D If they say, "ah no, I've been running it on 95 for years" then i'll be out of there.
  • 4 weeks later...
say what? is that really true that you should not use 95ron fuel in a standard unmolested road car?
I find that hard to believe, esp as the engine is the same as the one used in the nissan people carrier thing, which is hardly geard for performance.
i know pinking can happen in some highly tuned cars but........................
I always use either super or V power, but that is not because i thought I HAD to!.
No - I think you mis-read - keep using the super :thumbs:
