Adjust brake or accelerator pedal
Shinjuku
you can get the 380Z pedal which has a lip to it making it closer to the brake.
I still found the zed a difficult car to heel and toe in even with the pedal. My dodgy ankle just would bend right for it.
the other cure for this which i didn't do but think would have solved the problem is raise the brake pedal slightly, or it might have been to lower it, can;t remember its been so long. but that is a possible mod to do if a little fiddly working under the steering wheel.
I have the nismo pedal and I agree it makes a lot of difference laterally. My heel and toe was coming on quite well with it. However, ive bought myself a pair of race boots so I have a pair of shoes which will provide good pedal feel but more importantly give consistency when driving.
However the sole of the shoes being thin has had the effect of giving me a bit less reach on the heel - where what you are looking to do is pivot the heel right and then quickly down without simultaneously increasing pressure on the brake.
Really then what I need is to drop the brake pedal by a centimeter or two so that I need to make a less significant downward movement with the heel. The lateral position is fine with the nismo pedal.
Is there a way to make such an adjustment?
Cheers
Shinjuku
