Clicking noise transmission shaft
keiichi tsuchiya
after installing the LSD I found after about 10000km a clicking noise coming from the tree ... What can be? bearing anti vibration or noise?
or am I in danger of splitting the whole tree?
the click is created only when I remove gas and reissue the command, and only above a certain power (however minimal).
(I always apologize for my English but I use google translate, I'm Italian :blush: )
I thank you in advance for the advice and information.
Thanks to all!
Common problem, try this first: viewtopic.php?f=9&t=60165
If that doesn't fix then replace the CV joint - :pmzmanalex:
I also have the clicking noise but this is not ... This is very quiet as noise ...
mine is a blow dry and strong from inside the shaft. my mechanic says it's some rubber inside ...
but you say that component? PS ... I do not understand!?!?
you can explain better? so before you buy something I inquire if I should try to replace it :)
