spike4real Posted August 30, 2016 Share Posted August 30, 2016 Massive thanks! Only cost me £40 in tools instead of 4 hours labour from Nissan (quoted 2 hours per side). Fantastic! Quote Link to comment Share on other sites More sharing options...
ElliotBZ33 Posted April 12, 2017 Share Posted April 12, 2017 Hello guys. I am new to Zed ownership and new to the forum. It seems like a fantastic guide. However i own a 2006 350z and this clicking has only just started. I am fairly competent with cars but noises make me anxious lol. Newbie asf questions 1) am i going to be ok driving it like this until i have time to fix 2) can anyone recommend the right tools for getting wheel bolts off, axle bolt off etc 3) recommendation on grease 4) Particular area to apply grease to? photo? 4) Any Nissan/ Jap specialists near Berkshire? RG18 Thanks Quote Link to comment Share on other sites More sharing options...
reeceybeaney Posted April 12, 2017 Share Posted April 12, 2017 My '54 Z with 69k miles has just started to click, unsure if it has done before... But will be trying this as soon as I get a chance as it seems to have good success rates! Anyone had the click come back??? Hello guys. I am new to Zed ownership and new to the forum. It seems like a fantastic guide. However i own a 2006 350z and this clicking has only just started. I am fairly competent with cars but noises make me anxious lol. Newbie asf questions 1) am i going to be ok driving it like this until i have time to fix 2) can anyone recommend the right tools for getting wheel bolts off, axle bolt off etc 3) recommendation on grease 4) Particular area to apply grease to? photo? 4) Any Nissan/ Jap specialists near Berkshire? RG18 Thanks If you go back through the post (maybe on the first page) there's a photo showing the two areas to grease, it's the collar of the shaft not the actual spline that needs greasing which means it doesn't need to be removed completely. I've been recommended a good quality EP2 grease which is nice and thick, not like the type of thin stuff most garages use. Use normal socket set tools to get the wheel off (+ locking wheel nut key obviously) and then a 32mm (1 1/4") socket for the centre nut once the wheel is off. If you have the basic tools and a basic knowledge of using a socket set then you should be fine! Quote Link to comment Share on other sites More sharing options...
Mark261288 Posted May 2, 2017 Share Posted May 2, 2017 Something so simple to fix such an annoying fault. 👠Thanks... Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted May 8, 2017 Share Posted May 8, 2017 Seen someone on youtube use Blue lock tight for this, they applied it to the splines though, im guessing it's not the best idea ? Quote Link to comment Share on other sites More sharing options...
xxx180 Posted June 5, 2017 Share Posted June 5, 2017 Worked for me. Cheers for the advice guys 👠Quote Link to comment Share on other sites More sharing options...
Bhupz350 Posted June 27, 2017 Share Posted June 27, 2017 I have a clicking noise on the front passengers side, although there are no CV joints in the front. Its rotational and only seems to click when turning left or right. Any ideas? Quote Link to comment Share on other sites More sharing options...
parello9 Posted June 27, 2017 Share Posted June 27, 2017 Anyone in bedfordshire that can do this? Quote Link to comment Share on other sites More sharing options...
z350convert Posted August 6, 2017 Share Posted August 6, 2017 Just to kick this thread off again, I am a member of the clicking drive shaft club and I found this YouTube feature promoting the notion of using thread lock instead of grease. Willsy1980 asked for comments on this but no one seems to have tried it. Any thoughts? 1 Quote Link to comment Share on other sites More sharing options...
z350convert Posted August 30, 2017 Share Posted August 30, 2017 I'm going to go at this. I noticed that the Nissan bulletin stated new bolts, spring washers and nuts were needed when taking the axle from the diff so I went to local Nissan dealer to order them. The Parts manager came out and said frankly there was no need to replace them but I would need new cotter pins which he went and got for me and said there was no charges. He also said get both axles out and lube the splines and back of splines, but also get some CV grease in the CV joint itself. No mention of the marine grease I was looking for to put on the axle so I think I might get some for that purpose anyway. I hope this isn't going to one of those jobs I wish I hadn't started. Quote Link to comment Share on other sites More sharing options...
Junkyardbear Posted January 1, 2018 Share Posted January 1, 2018 Mins just started @45.000 miles Does it when I select reverse(auto) and pulling off. I've got 2 months warranty left from the sales garage @ £80 A hour labour and up to £5000 So shall I 're grease the drive or get a new updated one and claim on warranty? Quote Link to comment Share on other sites More sharing options...
Peeege Posted July 11, 2019 Share Posted July 11, 2019 Next job on the agenda the " clicky axle syndrome " anybody have an idea of split pin size ? Thanks in advance Quote Link to comment Share on other sites More sharing options...
1CE Posted July 31, 2019 Share Posted July 31, 2019 I still haven't done mine. Everytim I try and take the nut off it feels like the rear end is going to pull off ! So I chicken out. Quote Link to comment Share on other sites More sharing options...
Sheep_Flavour Posted February 28, 2021 Share Posted February 28, 2021 Apologies if this is a dull question, but with the clicking does it matter? Is it somthing that needs to be sorted right away or very dangerous or can be sorted when I have time. I hear a clicking on mine but only when roof or window is down so I assume it’s this but not sure. Just wondered if it is this? Quote Link to comment Share on other sites More sharing options...
Rikz2004 Posted March 1, 2021 Share Posted March 1, 2021 I'm not sure of the answer to your question, but mines had this when I bought it (the previous owner didn't even notice it, so who knows how long it actually had the issue for). I had it fixed aafter around 6ish months of owning the car I think. It's been completely fine since then, so doesn't seem like it did any long term damage. Quote Link to comment Share on other sites More sharing options...
Sheep_Flavour Posted April 6, 2021 Share Posted April 6, 2021 On 01/03/2021 at 22:33, Rikz2004 said: I'm not sure of the answer to your question, but mines had this when I bought it (the previous owner didn't even notice it, so who knows how long it actually had the issue for). I had it fixed aafter around 6ish months of owning the car I think. It's been completely fine since then, so doesn't seem like it did any long term damage. Thanks mate 😃 Quote Link to comment Share on other sites More sharing options...
MTAC Posted March 24, 2022 Share Posted March 24, 2022 I just brought a 2010 roadster and got the same clicking sound! Is there any safety issue with it as I planned to fix it later by a garage? Thanks. Quote Link to comment Share on other sites More sharing options...
