Karlp Posted March 30, 2012 Share Posted March 30, 2012 Hey guys, Been using my snow foam lance and nifisk for a few months now but cant seem to get the right consistency with the snow foam, it seems to be coming out as more of a milkshake than a foam and hardly sticking to the car, it just keeps running off and leaves a very thin layer on the car? Im putting about 1 - 2 inches of snow foam solution in the bottle than filling it with water, Im using some i4detailing snow foam. Do I need another snow foam solution or has anyone else had problems with nilfisk and snow foam lances? Quote Link to comment Share on other sites More sharing options...
SteveRS Posted March 30, 2012 Share Posted March 30, 2012 I use Autobrites Magifoam with a bog standard cheap Karcher k2 and Autobrite snow foam lance. It seems to foam up fine and sticks well. I put 2" in the bottle. I think the pressure of your pressure washer has a lot to do with how well the snow foam actually foams and sticks, mine doesn't foam as well as I would like but it works ok. Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 30, 2012 Share Posted March 30, 2012 Sounds like you've got the mixture knob set incorrectly on the lance. I had the same problem until I realised that the + and - was for how much water you wanted, not how much snow foam Quote Link to comment Share on other sites More sharing options...
rtbiscuit Posted March 30, 2012 Share Posted March 30, 2012 i think pressure makes a huge difference. i have a baby bosch pressure washer it produces more a milkshake than a foam. Quote Link to comment Share on other sites More sharing options...
Karlp Posted March 30, 2012 Author Share Posted March 30, 2012 Looks like a pressure issue than chaps, I fiddled with my knobs also . Looks like my milkshake will be bringing all the zeds to the yard... Quote Link to comment Share on other sites More sharing options...
Ricey Posted March 30, 2012 Share Posted March 30, 2012 Sounds like you've got the mixture knob set incorrectly on the lance. I had the same problem until I realised that the + and - was for how much water you wanted, not how much snow foam Plus 1......pain in the ass getting it right. Quote Link to comment Share on other sites More sharing options...
dragon Posted March 30, 2012 Share Posted March 30, 2012 Looks like a pressure issue than chaps, I fiddled with my knobs also . Looks like my milkshake will be bringing all the zeds to the yard... Sounds like your a kelis fan Quote Link to comment Share on other sites More sharing options...
ChrisS Posted March 30, 2012 Share Posted March 30, 2012 Do you wash the lance head after using it ? As they often get gunged up. If not try soaking it in warm water and detergent over night. You only need an inch of concentrate in the bottle. One of the plunger type dispensers is great as it's just 4 pump to a bottle. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted March 30, 2012 Share Posted March 30, 2012 Do you wash the lance head after using it ? As they often get gunged up. If not try soaking it in warm water and detergent over night. You only need an inch of concentrate in the bottle. One of the plunger type dispensers is great as it's just 4 pump to a bottle. I would say this or mixture knob. What Nilfisk are you using? I have a C110 and it makes lovely shaving foam like foam Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted March 30, 2012 Share Posted March 30, 2012 On advice from Tim @ Envy Valeting, I mix the snow foam detergent with cold water. Got a Karcher K2 myself and my mate had the same issue as you whilst having a Karcher also. He cleaned the lance nozzle out and it made foam again. Personally I have the adjuster knob on minimum water mix. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted March 31, 2012 Share Posted March 31, 2012 I noticed that mine was getting progressively worse (after I figured out the mixture knob like others ), I followed this handy guide (clicky) to cleaning my lance and it's much better now. Quote Link to comment Share on other sites More sharing options...
choptop Posted March 31, 2012 Share Posted March 31, 2012 Wash it by hand with a woolen mitt and rinse with a hose afterwards......................................simples. Quote Link to comment Share on other sites More sharing options...
james1989 Posted March 31, 2012 Share Posted March 31, 2012 how much of a differance does using a snow foam lance over traditional sponge and bucket actually is there? ive been considering all this for a while now and not sure, especially where i have my car parked its a pita to setup if the results scratch wise arent all that different Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted March 31, 2012 Share Posted March 31, 2012 how much of a differance does using a snow foam lance over traditional sponge and bucket actually is there? ive been considering all this for a while now and not sure, especially where i have my car parked its a pita to setup if the results scratch wise arent all that different Sponge? SPONGE?!?!?!? Please desist from using a sponge and switch to a washmitt, that will be the first step to avoiding scratches. Sponges tend to push dirt particles into the paintwork, thus causing scratches, a washmitt picks those particles up avoiding scratches. Snowfoam helps pull down the initial layer of dirt and debis, thus reducing the amount of particles that could potentially cause scratching. Quote Link to comment Share on other sites More sharing options...
