ivicdesigns Posted March 30, 2012 Share Posted March 30, 2012 I have just had an oxygen sensor changed (sensor 2 bank 2) after a P0057 error code on my 04 reg 350Z. After about 5 miles the engine management light came back on and the same error code appeared. Can anyone suggest a cure? Thank you all. Ivor Quote Link to comment Share on other sites More sharing options...
Bry Posted March 30, 2012 Share Posted March 30, 2012 Did the garage change the correct sensor ? Quote Link to comment Share on other sites More sharing options...
ivicdesigns Posted March 30, 2012 Author Share Posted March 30, 2012 Yes, so they say. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 30, 2012 Share Posted March 30, 2012 Sensors in stock and good to go same/next day if required Alex Quote Link to comment Share on other sites More sharing options...
ivicdesigns Posted March 30, 2012 Author Share Posted March 30, 2012 They replaced Right rear sensor! Quote Link to comment Share on other sites More sharing options...
Bry Posted March 30, 2012 Share Posted March 30, 2012 Yes, so they say. Bank 2 sensor 2 is the passenger side one furthest away from the engine have a look to see if it looks new just to confirm they've changed the correct one Quote Link to comment Share on other sites More sharing options...
ivicdesigns Posted March 30, 2012 Author Share Posted March 30, 2012 Bry, Thank you for that information the sensor supplier said it was Right rear! Will try swapping old right sensor for left side. Cheers, Ivor Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 30, 2012 Share Posted March 30, 2012 Bry, Thank you for that information the sensor supplier said it was Right rear! Will try swapping old right sensor for left side. Cheers, Ivor They are handed: Alex Quote Link to comment Share on other sites More sharing options...
ivicdesigns Posted March 30, 2012 Author Share Posted March 30, 2012 Bry, Have spoken to Nissan. Bank 2 is definetly right hand side. Need to try diagnostic check. Is this likely to help? Ivor Quote Link to comment Share on other sites More sharing options...
Bry Posted March 31, 2012 Share Posted March 31, 2012 Bry, Have spoken to Nissan. Bank 2 is definetly right hand side. Need to try diagnostic check. Is this likely to help? Ivor Right rear as you look at the car would be the passenger side 02 sensor. It might be worth getting a Diagnostic check as it may be pure bad luck that another sensor has also gone ? If you live near Kent, I have a Code reader you could use or you could check the code your self by doing the pedal dance method. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 31, 2012 Share Posted March 31, 2012 To be clear: Bank 2 is the passenger side providing your car is RHD: Alex Quote Link to comment Share on other sites More sharing options...
