Mrdeli Posted March 30, 2012 Share Posted March 30, 2012 Hello, I have a 2005 zed I am wanting to upgrade the head unit. Mine is none Bose and I have already upgraded the front speakers to infinity 62.5 kappa components The two units I am looking at are as follows: http://www.caraudiodirect.co.uk/jvc-kw-xr811.html http://www.caraudiodirect.co.uk/alp-cde ... 235bt.html I am wondering whether either of these is likely to bring a good uplift over the standard head unit or do I need to spend more for this to happen. I would also appreciate if someone could recommend the best quality fascia adapter for use with theses (or one for single din if that's a better fit). I would like the car to look as near oem as possible. Last time I changed the stereo on a ford the fascia unit was of really poor quality and a rubbish fit - I'm keen to avoid that on the Z. Thanks all. Mark. Quote Link to comment Share on other sites More sharing options...
un1eash Posted March 30, 2012 Share Posted March 30, 2012 Both would be an improvement in quality over the stock headunit. I would normally always pick Alpine but that alpine headunit although decent only as a single 2v preout which limits you if you ever wanted to expand your system and add amps for your speakers and a subwoofer. Saying that though you could still run an amp for your fronts and a subwoofer/amp but you wouldnt have full control from the headunit. Quote Link to comment Share on other sites More sharing options...
Mrdeli Posted March 30, 2012 Author Share Posted March 30, 2012 I hadn't considered that. Thanks. Ill have a further look and think whether I'd want to maybe upgrade again at a later time. Cheers mark. Quote Link to comment Share on other sites More sharing options...
