stuarty Posted March 28, 2012 Posted March 28, 2012 I clayed today for the first time. I used dodo juice clay bar and lube. After claying ive noticed some marring on the paint work. I then hand polished using dodo juice lime prime but it didnt remove the marring. Question is, would using auto glym srp remove the marring or do i need someone to machine polish it out? By the way i used plenty lube and i wet every panel before claing as it was a warm day! Quote
Zugara Posted March 28, 2012 Posted March 28, 2012 Respray needed...... PM tim at envy mate, he will assist your question. Quote
stuarty Posted March 28, 2012 Author Posted March 28, 2012 Respray needed...... PM tim at envy mate, he will assist your question. Cars only 5 weeks old with 400 miles. Quote
Zugara Posted March 28, 2012 Posted March 28, 2012 I did have some of these on my zed, I think it's where the clay dries out a little bit and sticks to the paint. I am sure I used my buff daddy to get them out. Quote
stuarty Posted March 28, 2012 Author Posted March 28, 2012 I did have some of these on my zed, I think it's where the clay dries out a little bit and sticks to the paint. I am sure I used my buff daddy to get them out. Am i correct in saying the marring can be polished out by a pro? Quote
Dblock Posted March 28, 2012 Posted March 28, 2012 Respray needed...... PM tim at envy mate, he will assist your question. Cars only 5 weeks old with 400 miles. new bmw's have terrible paint apparantly Quote
bronzee Posted March 29, 2012 Posted March 29, 2012 I clayed today for the first time. I used dodo juice clay bar and lube. After claying ive noticed some marring on the paint work. I then hand polished using dodo juice lime prime but it didnt remove the marring. Question is, would using auto glym srp remove the marring or do i need someone to machine polish it out? By the way i used plenty lube and i wet every panel before claing as it was a warm day! You may have marred it, or semi burned the paint through not using enough fluid to keep the bar sliding across the surface. Can you post a picture please. Quote
stuarty Posted March 29, 2012 Author Posted March 29, 2012 I clayed today for the first time. I used dodo juice clay bar and lube. After claying ive noticed some marring on the paint work. I then hand polished using dodo juice lime prime but it didnt remove the marring. Question is, would using auto glym srp remove the marring or do i need someone to machine polish it out? By the way i used plenty lube and i wet every panel before claing as it was a warm day! You may have marred it, or semi burned the paint through not using enough fluid to keep the bar sliding across the surface. Can you post a picture please. Ive tried to take a photo mate but its not really that obvious in the photo. Ive booked it in for a machine polish on monday. Quote
