Wasso Posted March 28, 2012 Share Posted March 28, 2012 Sam, where did you get your pillar pod from? Quote Link to comment Share on other sites More sharing options...
wizard Posted March 28, 2012 Share Posted March 28, 2012 Wizard you can always get one of these http://www.frsport.com/ATI-EZ-Pod-Dual- ... 29151.html Replaces the top plastic behind steering wheel, a bit TVR me thinks. Alternatively it's RSW for a a-pillar pod, but pricey! Hey Wasso, that looks like ears.... cool! Yeah i've already got the RSW pod, nice fitment, but very pricey. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted March 28, 2012 Author Share Posted March 28, 2012 Sam, where did you get your pillar pod from? Its the RSW pod. I got it from Ian when he split his car. Quote Link to comment Share on other sites More sharing options...
4RE Leather Posted March 31, 2012 Share Posted March 31, 2012 I sold a Stillen one to the guy that hit a Fox. His names Ben but I can't recall his forum name. He might be able to help answer questions What would the Fox want with his oil cooler Chris? Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted April 10, 2012 Author Share Posted April 10, 2012 (edited) Just a little update for those interested. After lots of searching around at different Oil Cooler kits and making up custom kits from parts, I've ordered this: http://www.driftworks.com/thermostatic-oil-cooler-kit-for-sr20det-vvt-s14-s15.html Its not intended for the 350z but for the S14/S15. I've checked all the parts included and it will fit the Zed fine (driftworks have confirmed this also). The 2 main benefits of this kit are 1. Its cheap! and 2. The Thermostatic Sandwich plate included is set to open at 92degC instead of the usual 80. This will allow the oil to warm up nicely and shouldn't suffer from the cooler (sub 80deg) oil temp in the winter which I wanted to avoid. Unfortunately, they are not able to give group buy discounts. I'm hoping to fit it in the next couple of weeks, so will update with fitting and temp findings after. Edited January 6, 2013 by Sam Mcgoo Quote Link to comment Share on other sites More sharing options...
Keyser Posted April 10, 2012 Share Posted April 10, 2012 Looks good Sam - do let us know how it goes Quote Link to comment Share on other sites More sharing options...
Neilp Posted April 10, 2012 Share Posted April 10, 2012 Looks good Sam - do let us know how it goes +1, I'm in contact with CS also who is sorting a little somethingsomthing Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted April 16, 2012 Author Share Posted April 16, 2012 Right then, I managed to fit the Driftworks 19 row oil cooler kit today. I've mounted it to the side of my intercooler and have tried to get as much of it in direct air flow as possible. I think its probably about 2/3 exposed. Been for a drive and it looks good so far. Quite a cool day, (11C) oil quickly warmed up to 80degC and pretty much stayed there while normal driving. Spirited driving got it up to about 92 but it quickly went down to 84 when in the cruise. Just as a test to see if it would get hot, I done a stationary test keeping the revs at 3k for about 2 mins and it soon got up to 100. Pulled away and within a minute it was back down to about 85. I will do some more monitoring over the next few days, but my initial impression is that is lowered my oil temps by about 5degC while driving normally but during spirited driving its lowered it by about 20degC ! Regarding the thermostatic sandwich plates and their temperature ratings, I think they start to open quite a bit lower then it states but is fully open by the stated temperature. My one is rated at 92 degC but it was definitely flowing some oil through the cooler at around 70 but not a lot, when I was pushing it it didn't go above the 92 that it states so would suggest that it was fully open. I suppose it would make sense as you wouldn't want cool oil in the cooler suddenly going into a HOT engine when it opened. Anyway, time will tell. Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted April 16, 2012 Share Posted April 16, 2012 What sort of thermo plate you running Sam? 2 types both work a different way. Quote Link to comment Share on other sites More sharing options...
djtimo Posted April 16, 2012 Share Posted April 16, 2012 Looking good! Quote Link to comment Share on other sites More sharing options...
andlid Posted April 16, 2012 Share Posted April 16, 2012 sweet install, where is the uptake for the heat sensor? think mine opens a bit earlier too... not sure if its per design... Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted April 16, 2012 Author Share Posted April 16, 2012 What sort of thermo plate you running Sam? 2 types both work a different way. Mocal 92 Deg Thermostatic sandwich plate. What are the differences between the two Mark? Looking good! Cheers Tim. sweet install, where is the uptake for the heat sensor? think mine opens a bit earlier too... not sure if its per design... My temperature sensor is mounted in a sandwich plate. Where is yours then? Also, the standard Thermo plates are set at 80degC so your is probably opening earlier than mine. Quote Link to comment Share on other sites More sharing options...
andlid Posted April 16, 2012 Share Posted April 16, 2012 same mocal plate as you mate same temp pos as you too! Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted April 17, 2012 Share Posted April 17, 2012 presume you have the take off plate type fitted , this uses a wax thermostat to divert all the oil until the oil warms the wax thermostat up and moves the gate out of the way to allow the oil to flow via the oil cooler The other thermostat still uses a wax thermostatic valve but the unit goes in the pipework to the oil cooler , it uses the added resistance of thick oil through a cooler to make the oil divert around the cooler by when the thermostatic valve is cold (closed) the oil will take the easiest route which is not through the cooler it doesn't shut of the flow to the cooler. once the oil thermostat is warm it shuts and the oil has to flow via the cooler. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted April 17, 2012 Author Share Posted April 17, 2012 Yeah I have the take off plate style. Thanks for the info Mark. Quote Link to comment Share on other sites More sharing options...
