lukekbrown Posted March 25, 2012 Share Posted March 25, 2012 I fitted my JWT pop charger today but decided to not install the heat shield as I think it looks Obviously the heat shields role is to protect heat from the engine to the JWT or vice versa. My question is will this affect performance or any other possible defects? As would prefer to fit the shield than cause damage. I've also started to get idling problems with the JWT fitted The car starts fine, then the rev counter goes up then drops to 0 and cuts out. But if I slightly touch my accelerator it idles okay. What could this be? How do I fix the problem? Thanks Quote Link to comment Share on other sites More sharing options...
Dblock Posted March 25, 2012 Share Posted March 25, 2012 check air leaks, check the maf is plugged in and clean the maf with a special cleaner. Quote Link to comment Share on other sites More sharing options...
lukekbrown Posted March 25, 2012 Author Share Posted March 25, 2012 Probably a stupid question but how do I check for air leaks? I didn't remove the MAF sensor from the intake pipe when fitting the JWT, so that shouldn't be the problem? I might unplug and replug the MAF, see if that fixes it (Maybe it has to be reset?). Quote Link to comment Share on other sites More sharing options...
m-zed89 Posted March 25, 2012 Share Posted March 25, 2012 Did you reset the ecu by removing the negative from the battery for 30 mins? Fitted mine with no problems. The heat shield is meant to reflect some of the engine heat so i would recomend fitting it Quote Link to comment Share on other sites More sharing options...
Dblock Posted March 25, 2012 Share Posted March 25, 2012 listen for hiss's or if you spray/smoke something non flamable you can see if you have a leak there. Remember there is a small pipe that needs to be connected under the intake pipe. Did you screw the maf in properly? sorry just read you didnt move it. The same sort of thing happened to me when I forgot to screw the maf in so thought it might be that. Maybe put up a picture then someone can tell you if you fitted it right? Quote Link to comment Share on other sites More sharing options...
Ricey Posted March 26, 2012 Share Posted March 26, 2012 Yes you'll get heat soak off the engine....hence a he's shield being included Quote Link to comment Share on other sites More sharing options...
cmck13 Posted March 26, 2012 Share Posted March 26, 2012 Yes you'll get heat soak off the engine....hence a he's shield being included Correct, its supplied with a heat shield because heat is detrimental to the air flow. Quote Link to comment Share on other sites More sharing options...
lukekbrown Posted March 26, 2012 Author Share Posted March 26, 2012 Looking at the positioning of the heat shield on the JWT, it's going to get heat on the filter whether the heatshield is there or not, I assume the filter needs to be enclosed completely to remove all heat soak? If I left the heat shield off what am I really going to lose out on? If it's only a few hp then I'll live with that, ss I don't track my car, nor thrash it on the roads, just some spirited few hundred yards here and there I think the fitment is really poor of the heatshielf and is more likely going to come off than stop heat soak! Maybe I am missing the point? Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted March 26, 2012 Share Posted March 26, 2012 The problem wouldn't be on a track or spirited drives here are there it will be when you are sitting in traffic with no cold air if it wasn't required then JWT would have cut down their costs and not bothered with it Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted March 26, 2012 Share Posted March 26, 2012 I think the fitment is really poor of the heatshielf and is more likely going to come off than stop heat soak! Maybe I am missing the point? It will be fine Luke, it won't go anywhere once fitted correctly Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted March 26, 2012 Share Posted March 26, 2012 I think the fitment is really poor of the heatshielf and is more likely going to come off than stop heat soak! Maybe I am missing the point? It will be fine Luke, it won't go anywhere once fitted correctly Agreed they fit tight as a drum, I always thought about spraying mine as the gold does look out of place but then I am not an engine bay queen Quote Link to comment Share on other sites More sharing options...
lukekbrown Posted April 4, 2012 Author Share Posted April 4, 2012 I think the fitment is really poor of the heatshielf and is more likely going to come off than stop heat soak! Maybe I am missing the point? It will be fine Luke, it won't go anywhere once fitted correctly I found out that I had a rubber grommet missing, which supported the heat shield. So got a new rubber grommet and the heatshield fits great now Idle problems were sorted by doing an idle reset Quote Link to comment Share on other sites More sharing options...
