Concentric slave cylinder on 313 gone again!!!
Greekman
As the title says......it's knackered....again :rant:
It's the 4rd one in 44k miles! First one lasted about 13k. Second one lasted about 12k. Third another 15k ish and this one only 4k!
It's a gearbox down job (not down on the floor but still about 14 screws plus the bracings later to open the clutch compartment) and frankly I am getting fed up!
First was on oem clutch fluid. Second on motul 5.1 or smth third on RBF 660 and this one on god knows what as I had it replaced at a Honda dealership in Greece!!!
This last one did only 6 laps at the ring and not a single track day apart from that plus 2k miles were done driving back from Greece.
Is there anything stronger/different.....Anything! I could do to stop this from happening? Last time at 40k when I had the last one fitted the clutch looked like new!! And that's 25k later and many track days.
Any input very much appreciated.
Ps I ve got the feeling that it's the high temperatures that are killing it, as the fluid is cooking the rubber seal hence on the 660 it lasted the longest.
Chris,
I would wrap all exhaust stuff that is close to the clutch lines and tube.
I would also wrap the clutch lines and hose.
I would also recommend that you swop out the concentric tube as well as the concentric slave.
viewtopic.php?f=157&t=57096
viewtopic.php?f=157&t=57094
Both these parts are in stock and good to go same/next day mate :thumbs:
Alex :)
Chris,
Alex :)
Thanks for the input Alex. I was going to change the tube this time round anyway.
I ll be in touch soon anyway a few bits and bobs :)
