Mrdeli Posted March 19, 2012 Share Posted March 19, 2012 Hi everyone. Well I did the iPod tape hack today and also replaced the plugs. I've been reading up on cleaning the maf sensor and throttle body. Can you advise whether the following sounds about right? 1. Maf: disconnect from the inlet pipe and spray wires with cleaner. 2. Throttle body. Disconnect neg from battery, then harness from TB. Remove inlet pipe from TB, then remove screws holding TB on. Once removed clean with TB cleaner. I understand that care is needed, but the flap can be moved manually when cleaning. Reassemble. Any advise or comments appreciated Thanks mark. Quote Link to comment Share on other sites More sharing options...
Dblock Posted March 19, 2012 Share Posted March 19, 2012 I would spray the maf with the cleaner not the wires? Make sure its proper maf cleaner though and just spray and let it dry itself. dont touch or dry it with anything. Yes you can do that but its pretty hard and limited space. Once finished cleaning do the throttle reset. video here. Quote Link to comment Share on other sites More sharing options...
Zugara Posted March 19, 2012 Share Posted March 19, 2012 Don't move the flap. Clean with care Quote Link to comment Share on other sites More sharing options...
Mrdeli Posted March 19, 2012 Author Share Posted March 19, 2012 Please could someone recommend the best product to clean the throttle body with. I see crc sensor cleaner is recommended for the maf, would this be good to use on the throttle body too? Thanks mark. Quote Link to comment Share on other sites More sharing options...
glrnet Posted March 19, 2012 Share Posted March 19, 2012 Wynns Carb Cleaner Quote Link to comment Share on other sites More sharing options...
Mrdeli Posted March 19, 2012 Author Share Posted March 19, 2012 Thanks. I'd read on some posts that carb cleaner was not good for some throttle bodies as it can strip the coating off the throttle body. I go with your advice though. Thanks mark Quote Link to comment Share on other sites More sharing options...
Zugara Posted March 19, 2012 Share Posted March 19, 2012 Really Graham, I used Tardis when I did mine and it came up really clean, although I had to use a small paint brush to get the tardis to work. Does Wynns need any help, or does the crud melt away? Wynns Carb Cleaner Quote Link to comment Share on other sites More sharing options...
Mrdeli Posted March 19, 2012 Author Share Posted March 19, 2012 Had anyone used Seafoam Deep Creep - it seems to work without the need to remove the throttle body. As a matter of interest, how long has it taken to: A. Remove the throttle body B. Clean the throttle body Also are any replacement gaskets or the like needed, Thanks. Quote Link to comment Share on other sites More sharing options...
Mrdeli Posted March 20, 2012 Author Share Posted March 20, 2012 Please could someone tell me whether I need to get a new gasket if I am going to take off and clean the throttle body? If so, where would I get one? Thank you. Mark Quote Link to comment Share on other sites More sharing options...
Zugara Posted March 20, 2012 Share Posted March 20, 2012 for gaskets mate. Gaskets should always be replaced if they are disturbed Quote Link to comment Share on other sites More sharing options...
doctor austin Posted March 20, 2012 Share Posted March 20, 2012 No you dont need to change the gaskets unless you damage them...unlikely though. I would/have used contact cleaner to clean the fine wire on the MAF hot wire sensor..personally would keep away from carb cleaner as its too harsh. I would also recommend you check that the plug and socket connections are not corroded...and give them a clean. One issue with pretty much all the engine management sensors is they are low voltage so susceptible to poor contact. Quote Link to comment Share on other sites More sharing options...
Mrdeli Posted March 21, 2012 Author Share Posted March 21, 2012 Thanks for that - I have ordered crc sensor cleaner for the maf, which from what I have read is the best stuff. I'm going to order a specific throttle body cleaner for the TB, but am unsure as yet which one to go for. I think I'm pretty lucky with my Z as everything under the bonnet is corrosion free. One thing I have noticed is that I filled up with Tesco 99 Ron, and that night left the negative disconnected and I swear she is running even better 1 Quote Link to comment Share on other sites More sharing options...
Mrdeli Posted March 22, 2012 Author Share Posted March 22, 2012 Cleaned the MAF today. (79000 miles) It really was a 10 minute job. Used crc sensor cleaner. Removing the maf is just two screws. On inspection the maf seemed clean. A few sprays later, a few mins to dry off and then back in. Expecting nothing, I was surprised to find the engine definitely smoother. Effort v benefit - a definite no brainier. Throttle body on the weekend - bit more cautious about that one!! Wish me luck. Cheers all mark. 1 Quote Link to comment Share on other sites More sharing options...
GT4 Zed Posted March 22, 2012 Share Posted March 22, 2012 I really dont know what the fuss is with cleaning the TB? I use white spirit with a paint brush and do both sides and move the butterfly valve to clean the wall as some gunk always sits there. I then do the TB reset and the car always starts with no issues. I have never cleaned the MAF sensor before so will give it a go In anycase the Breather pipe spews most of the blowby oil into the intake plenum so if you can to clean this up for good then get a baffled oil catch on the breather side and or the PCv for the perfect combo Quote Link to comment Share on other sites More sharing options...
FUG Posted February 2, 2013 Share Posted February 2, 2013 Is white spirit receommended for the TB cleaning then?? Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 2, 2013 Share Posted February 2, 2013 Is white spirit receommended for the TB cleaning then?? I'd use carb cleaner personally but it might be the same stuff as white spirit. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted March 24, 2013 Share Posted March 24, 2013 Any idea on what size those sodding star key screws are ? FFS - why couldn't that be normal ! Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted March 28, 2013 Share Posted March 28, 2013 I ordered this set from ebay: http://www.ebay.co.uk/itm/160729342041?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 The tossers sent me a bloody snow/ice over shoe - I'm going to try and remove the bleedin screws tomorrow but I hope they are a normal thread as I'm going to replace them (I hope). Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted May 24, 2013 Share Posted May 24, 2013 Is there a reason to cleaning maf sensor and throttle body? and should i clean the o2 sensor aswell, im currently getting really crappy mpg and thats with oap driving!? Quote Link to comment Share on other sites More sharing options...
dErZ Posted May 24, 2013 Share Posted May 24, 2013 Dont give us that OAP driving lark we know that you cant control your right foot what with all those awesome roads up there Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted May 24, 2013 Share Posted May 24, 2013 Dont give us that OAP driving lark we know that you cant control your right foot what with all those awesome roads up there Lol yeh but i thought id try an mpg test... filled the tank up , reset trip meter and trying to make it last a week! The missus said if i manage it she will fill up my tank next week! started yesterday and already down to half a tank with only 122miles on the clock!? Or maybe its km but still doesnt it seem abnormal? @.@)/ Quote Link to comment Share on other sites More sharing options...
cs2000 Posted May 24, 2013 Share Posted May 24, 2013 Guess it depend where you drive. I use mine for comuting and a tank can last 300+ miles. But its all Dual carriageways until the last few miles in town. My trip meter shows an average MPG of 25.8 over 3 months of the same journeys. Quote Link to comment Share on other sites More sharing options...
glrnet Posted May 24, 2013 Share Posted May 24, 2013 Dont give us that OAP driving lark we know that you cant control your right foot what with all those awesome roads up there Lol yeh but i thought id try an mpg test... filled the tank up , reset trip meter and trying to make it last a week! The missus said if i manage it she will fill up my tank next week! started yesterday and already down to half a tank with only 122miles on the clock!? Or maybe its km but still doesnt it seem abnormal? @.@)/ Sounds like you have dirty fuel gauge floats, check this out:- http://www.350z-uk.com/topic/54763-how-to-fix-the-inaccurate-fuel-gauge/ Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted May 24, 2013 Share Posted May 24, 2013 Really? but my car only has 13000km on it, im going to try 55mph in 6th instead as previously i was trying 70mph. But what does cleaning the maf do? and would spark plug flooding with oil upto the top of sparkplug serious or will it just burn off? Quote Link to comment Share on other sites More sharing options...
SkylineV35 Posted May 25, 2013 Share Posted May 25, 2013 Hey guys erm.. im looking at the maf sensor right now its got a silverish metal plate and a hole with wires and resistors... which part do i spray or do you just drench the whole thing? Quote Link to comment Share on other sites More sharing options...
