Teins or Eibach lowering springs?
lukekbrown
Hi,
I want to get rid of the big gap between my wheels and arch, but don't want to start scraping my arches if I lower my car.
I have 20 inch wheels (Front set up is 245/30ZR20, rears set up is 275/30ZR20), I'm currently running 20mm spacers on the front and will be adding 20/25mm spacers to the rear when I lower my car.
So am in the predicament of deciding between Tein S or Eibach pro kit lowering springs. What do you think will be best for my requirements? Does anyone have Teins or Eibachs fitted with 20 inch wheels? I can only find forum members with 19 inch wheels...
Pic of my car with big gap between arch and wheels...
I'm mainly worried about rubbing against the arches because of the offsets on my wheels (big offset on the rears).
Do you know if running eibachs with a 30mm drop, with 20mm spacers front and rear with the below wheels offsets will cause no hassle?
Front wheel setup 245/30ZR20, offset 20 x 8.5
Rears wheel set up 275/30ZR20, offset 20 x 10
Thanks
