Suspect dualmass flywheel problems??
Tommo
Hi folks, got a bit of a problem with the 350z. Its a 2005 with 18'000 miles and I think the dual mass flywheel is possibly on its way out! Is this a common fault or has anyone else had experience of this? The symptoms are a slight rattle when the car is first started and also turned off (only when your foot is off the clutch) and also slight rattle when the car is in a high gear at low speeds and you accelerate slightly. When on the move it's fine but to me it has the symptoms of the dual mass flywheel, even although the car has only covered 18'000 miles! Any advice or experience would be appreciated, Thanks, Tommo.
Genuine Nissan OEM dual mass flywheels in stock and good to go same/next day if required :thumbs:
Also single mass aluminium lightened flywheels also in stock and good to go same/next day. :thumbs:
Drop me a PM if I can help you further mate :thumbs:
Alex :)
