Dave J Posted March 14, 2012 Share Posted March 14, 2012 Just fitted a set of Brembo discs & calipers but i just can't seem to get the air out of them. I did forget to tighten one pipe when i went to speak to a customer so i pulled in a load of air I spent a couple of hours bleeding them this morning in the correct order of R/N/S , F/O/S, R/O/S then F/N/S but there still seems to be air in the system. I've checked every pipe for leaks, there are none and i've checked every fitting and they are all nice and tight. Would the ABS pump also need bleeding? I've changed brakes many, many times and never had this problem before Any advice gladly accepted!!! Dave. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 14, 2012 Share Posted March 14, 2012 Just fitted a set of Brembo discs & calipers but i just can't seem to get the air out of them. I did forget to tighten one pipe when i went to speak to a customer so i pulled in a load of air I spent a couple of hours bleeding them this morning in the correct order of R/N/S , F/O/S, R/O/S then F/N/S but there still seems to be air in the system. I've checked every pipe for leaks, there are none and i've checked every fitting and they are all nice and tight. Would the ABS pump also need bleeding? I've changed brakes many, many times and never had this problem before Any advice gladly accepted!!! Dave. Can I ask how many bleed nipples you are bleeding and if are you bleeding using the traditional method ie: 2 men, bottle and hose or are you using specialised brake bleeding equipment.? Also did you allow the brake master cyl. reservoir to run dry? Alex Quote Link to comment Share on other sites More sharing options...
Dave J Posted March 15, 2012 Author Share Posted March 15, 2012 Just fitted a set of Brembo discs & calipers but i just can't seem to get the air out of them. I did forget to tighten one pipe when i went to speak to a customer so i pulled in a load of air I spent a couple of hours bleeding them this morning in the correct order of R/N/S , F/O/S, R/O/S then F/N/S but there still seems to be air in the system. I've checked every pipe for leaks, there are none and i've checked every fitting and they are all nice and tight. Would the ABS pump also need bleeding? I've changed brakes many, many times and never had this problem before Any advice gladly accepted!!! Dave. Can I ask how many bleed nipples you are bleeding and if are you bleeding using the traditional method ie: 2 men, bottle and hose or are you using specialised brake bleeding equipment.? Also did you allow the brake master cyl. reservoir to run dry? Alex Hi Alex, You most certainly can! Bleeding 6 nipples, 1 on each rear then inner and outer on the fronts. 2 men, bottle, clear hose and i may have quite possibly run the master cylinder to run dry at one point Dave. Quote Link to comment Share on other sites More sharing options...
Sam Mcgoo Posted March 15, 2012 Share Posted March 15, 2012 Just fitted a set of Brembo discs & calipers but i just can't seem to get the air out of them. I did forget to tighten one pipe when i went to speak to a customer so i pulled in a load of air I spent a couple of hours bleeding them this morning in the correct order of R/N/S , F/O/S, R/O/S then F/N/S but there still seems to be air in the system. I've checked every pipe for leaks, there are none and i've checked every fitting and they are all nice and tight. Would the ABS pump also need bleeding? I've changed brakes many, many times and never had this problem before Any advice gladly accepted!!! Dave. Can I ask how many bleed nipples you are bleeding and if are you bleeding using the traditional method ie: 2 men, bottle and hose or are you using specialised brake bleeding equipment.? Also did you allow the brake master cyl. reservoir to run dry? Alex Hi Alex, You most certainly can! Bleeding 6 nipples, 1 on each rear then inner and outer on the fronts. 2 men, bottle, clear hose and i may have quite possibly run the master cylinder to run dry at one point Dave. If you have the Brembos fitted to the rear, there is also 2 bleed nipples on each of them, one inside and one outside, as with the fronts. So you should be bleeding 8 nipples in total. Be aware that the the inside rears very often are seized, (as I found out yesterday!) so give them a good squirt of penetrating fluid a while before hand and be prepared to replace the nipples. (M10x1 nipples) I spent 3 hours getting 2 nipples out yesterday! I ended up resorting to a blowtorch and heat cycling them and gently working them back and forth. Damn Nissan putting steel nipples in an alloy caliper! Also, if you have run it dry you may have to use around 1-1.5 litres of fluid to get all the air out. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 15, 2012 Share Posted March 15, 2012 That is your problem mate: As Sam has said there are 8 bleed nipples in total. Should have went to Spec-Savers. Alex Quote Link to comment Share on other sites More sharing options...
Dave J Posted March 15, 2012 Author Share Posted March 15, 2012 I'm now totally confused as i'm almost certain there is only one nipple on each rear caliper I shall look again and report back, many thanks for your help guys!! Dave. Quote Link to comment Share on other sites More sharing options...
Dave J Posted March 15, 2012 Author Share Posted March 15, 2012 Well i am officially the 'idiot of the week'.............i've wasted several hours of my life bleeding Brembo brakes incorrectly Thanks you very, very much guys for your help, it is very much appreciated!!!! Dave. Quote Link to comment Share on other sites More sharing options...
andlid Posted March 15, 2012 Share Posted March 15, 2012 Quote Link to comment Share on other sites More sharing options...
Keyser Posted March 15, 2012 Share Posted March 15, 2012 You are only happy as he took your title for the week Quote Link to comment Share on other sites More sharing options...
Neilp Posted March 15, 2012 Share Posted March 15, 2012 You are only happy as he took your title for the week Quote Link to comment Share on other sites More sharing options...
cmck13 Posted March 15, 2012 Share Posted March 15, 2012 Hey don't worry mate we all drop one like this. Perfectly normal. Quote Link to comment Share on other sites More sharing options...
glrnet Posted March 15, 2012 Share Posted March 15, 2012 Look at it this way:- 1. You've learnt something 2. Some others have too 3. You won't forget in a hurry 4. How much have you saved because of the knowledgeable souls on here? Quote Link to comment Share on other sites More sharing options...
Dave J Posted March 15, 2012 Author Share Posted March 15, 2012 Yes i certainly have learned a lesson and i am extremely grateful to have been given good advice I did have a good laugh at myself for being such a numpty Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 15, 2012 Share Posted March 15, 2012 I did have a good laugh at myself for being such a numpty We all did as well mate Quote Link to comment Share on other sites More sharing options...
glrnet Posted March 15, 2012 Share Posted March 15, 2012 Took it on the chin as well, top man Yes i certainly have learned a lesson and i am extremely grateful to have been given good advice I did have a good laugh at myself for being such a numpty Quote Link to comment Share on other sites More sharing options...
elfman Posted March 16, 2012 Share Posted March 16, 2012 Took it on the chin as well, top man Yes i certainly have learned a lesson and i am extremely grateful to have been given good advice I did have a good laugh at myself for being such a numpty +1 we all make mistakes haha! Quote Link to comment Share on other sites More sharing options...
