simon da silva Posted March 13, 2012 Posted March 13, 2012 hey Guys. just installed OEM HID kit on my headlights, but the ballast dident have the o-Ring seal with them. Anybody knows what size they are, and where to buy them? Thx Quote
Madmarky Posted March 13, 2012 Posted March 13, 2012 Do you have a picture of where the missing bit would go, maybe i can help if i can work out what part you mean. Quote
simon da silva Posted March 13, 2012 Author Posted March 13, 2012 the seal should fit around the 7,5mm metal ring, to make a tight seal between headlight and ballast Quote
Madmarky Posted March 13, 2012 Posted March 13, 2012 I have a spare broken light ill look tomorrow for you. Quote
simon da silva Posted March 13, 2012 Author Posted March 13, 2012 sounds nice, i need 2 rings btw Quote
marzman Posted March 14, 2012 Posted March 14, 2012 the seal should fit around the 7,5mm metal ring, to make a tight seal between headlight and ballast Cant you just measure the outer diameter of the balast? Then if you cant find an o-ring of thiat size then use something else such as double sided tape, or silicone sealant etc. Quote
simon da silva Posted March 14, 2012 Author Posted March 14, 2012 I think this is what you need? looks about right Quote
