ZedHead Posted March 12, 2012 Share Posted March 12, 2012 Quick question to all those in the know. Does it stand to reason that if your revs don't change with A/C on or off the compressor is shot or will the compressor not work if the system needs regassed? Really hoping I don't have to shell out for a compressor. Alex (Zmanalex) you might need to have one on standby. Cheers Guys Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted March 12, 2012 Share Posted March 12, 2012 I don't think my revs changed at all with aircon on or off. Does it get cold when you put it on cold? If not then its bust ...... also do you get a puddle under the car when you park after having the aircon on? Quote Link to comment Share on other sites More sharing options...
Will370z Posted March 12, 2012 Share Posted March 12, 2012 Revs didnt change for me when i turned the air con on. Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 12, 2012 Share Posted March 12, 2012 Check your belt. I suspect it's missing. Same thing happened to me on my old car. Quote Link to comment Share on other sites More sharing options...
Ebized Posted March 12, 2012 Share Posted March 12, 2012 Engine will usually tickover at slightly higher revs with the air-con on. May just need a re-gas/topping up - a whole lot cheaper than a new compressor Quote Link to comment Share on other sites More sharing options...
ZedHead Posted March 12, 2012 Author Share Posted March 12, 2012 Belt definitely there as far as I can see. It's the belt right under the air intake isn't it? Hard to see if there isn't a puddle under the car at this time of year in the Hebrides. Maybe I'll run it in the garage for a while (don't worry, with garage door open) Quote Link to comment Share on other sites More sharing options...
JetSet Posted March 12, 2012 Share Posted March 12, 2012 Revs don't seem to drop on The Zed. From my limited experience of A/C then the bigger the engine the less the revs drop. Pete Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 12, 2012 Share Posted March 12, 2012 David, Zmanalex on standby with plenty of air con. compressors in stock if required mate The revs will drop slightly when you switch on the air con. There are two belts on the front of the engine, the shorter inner one is for the air con. If all looks good and you are not getting the air con to work then I would try a recharge first. If it does not hold pressure then get the garage to run a dye through the system to determine where the leak is. I will have all parts in stock to fix this for you if required including air con hard lines. Alex Quote Link to comment Share on other sites More sharing options...
ZedHead Posted March 12, 2012 Author Share Posted March 12, 2012 As ever Alex, It's nice to know you are there to dig me out of the poo again Quote Link to comment Share on other sites More sharing options...
rmgthatsme Posted March 13, 2012 Share Posted March 13, 2012 Just a thought but could it be a faulty on/off switch? Second suggestion is that if it's very cold where you are, have you turned the climate control dial to a low enough setting to actually activate the compressor? Sometimes can be the simple things that fail... Hope this helps Quote Link to comment Share on other sites More sharing options...
Darren-B Posted March 13, 2012 Share Posted March 13, 2012 Also might be worth checking that the ac clutch plate is still intact.( its a plate that bolts onto the front of the compressor) Mine fell off on the way back from the jock land hoon, found it on the under tray 500 miles after it came off Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 13, 2012 Share Posted March 13, 2012 revs go slightly up on tickover when switching on the aircon Quote Link to comment Share on other sites More sharing options...
ZedHead Posted March 14, 2012 Author Share Posted March 14, 2012 Thanks guys, I shall check all the possiblities out. Can anyone recommend a good do it yourself regassing system as my local garage in the Hebrides can't do it apparently? cheers Quote Link to comment Share on other sites More sharing options...
wizard Posted March 14, 2012 Share Posted March 14, 2012 Don't bother DIY the gassing yourself buddy. It's just not worth it. A refill kit costs the same as getting it done at halfords. Their machine will also tell you before it re-gasses whether there are any leaks. If so, get these rectified. Other points to note: 1) If you don't have any gas in the compressor, the aircon unit will NOT come on. 2) Check the belt is still there and has not come off or shredded. 3) The engine note should sound different as soon as you switch your aircon on as a test. The louder your exhaust, the more noticeable the sound. If all the above checks out then Alex is your man for a replacement unit. Hope this helps. Quote Link to comment Share on other sites More sharing options...
