Invidia N1 Wanted
Kavik
  • 3 weeks later...
My struggle is over, picked up a used one last night :)
Need some new gaskets & nuts 'n' bolts for it though.
Do you sell gaskets for them at all? Had a quick look on your site but could not see them listed.
Just get unniversal gaskets from ebay
you need :
2 x 2.5" 2 holes gaskets for the cats/decats to y-pipe
and 3x3" 2holes gasket for the center pipe and 2 end canister sections. Just lie the K-1 B)
i change them about twice a year as they all perish and leak. OEm gaskets and metal but they are 2.5" only max.
No worries mate, will try the Zman.
Should I be after gaskets with the metal ring in the center, or the 'plain' ones?
Does it matter? What do the new zorsts come with?
Cheers :)
They are usually just plain bud.
The metal shim OEM ones that are on your standard system are pretty good tbh if you can re use them
