john smith Posted March 2, 2012 Share Posted March 2, 2012 i bought these wheels viewtopic.php?f=32&t=57533 any way the cars in the garage and the fronts dont fit they catch the brembo calipers ??? must be different on the roadster, i need a set of spaces , and longer studs asap please any helpers ????? Quote Link to comment Share on other sites More sharing options...
SparksCW Posted March 2, 2012 Share Posted March 2, 2012 Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 2, 2012 Share Posted March 2, 2012 roadsters arent different. Try CS for spacers Quote Link to comment Share on other sites More sharing options...
evilscorp Posted March 2, 2012 Share Posted March 2, 2012 Do they have/need spigot rings? they look big enough to fit, and roadster should have the same brake setup. Quote Link to comment Share on other sites More sharing options...
WINKJ Posted March 2, 2012 Share Posted March 2, 2012 CS they do reaaaaally good prices and fast delivery Quote Link to comment Share on other sites More sharing options...
john smith Posted March 2, 2012 Author Share Posted March 2, 2012 cheers i was kinda hoping someone close might have some i will try the advised Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted March 2, 2012 Share Posted March 2, 2012 Thanks all, you sure the wheels aren't hitting the stud on the brake disc, make sure it's been removed... Quote Link to comment Share on other sites More sharing options...
M13KYF Posted March 2, 2012 Share Posted March 2, 2012 also worth getting some spigot rings if they dont have any anyway. This wont help with clearance though Quote Link to comment Share on other sites More sharing options...
Ebized Posted March 2, 2012 Share Posted March 2, 2012 I see Chris had 20mm spacers on with those wheels. What CS says ^^^ - I do trust the garage spotted that serves no useful purpose and needs removing. he will sort you out quick Quote Link to comment Share on other sites More sharing options...
john smith Posted March 2, 2012 Author Share Posted March 2, 2012 will 20 mm spacers need new studs ? Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted March 2, 2012 Share Posted March 2, 2012 will 20 mm spacers need new studs ? With the spacers that we do the studs are pressed into the spacers, so they're very easy to fit... You can see them on www.cougarstore.co.uk Quote Link to comment Share on other sites More sharing options...
john smith Posted March 2, 2012 Author Share Posted March 2, 2012 thankyou im an impatient sod , theres a place near me that has a set i can collect in the morning, if they dont fit (he says there ultralight ones? and there needs to be a pocket at the rear of the wheel for the standard stud to hide in ???) i will give you a call. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 2, 2012 Share Posted March 2, 2012 If all else fails then I have in stock exactly what you will require including spigot rings if you have a wheel to hub issue. Guaranteed next working day delivery If you are unsure what you require then just drop me a PM as informed technical advice is always readily available and it's free Alex. Quote Link to comment Share on other sites More sharing options...
glrnet Posted March 2, 2012 Share Posted March 2, 2012 And it's always accurate If all else fails then I have in stock exactly what you will require including spigot rings if you have a wheel to hub issue. Guaranteed next working day delivery If you are unsure what you require then just drop me a PM as informed technical advice is always readily available and it's free Alex. Quote Link to comment Share on other sites More sharing options...
