Jack points for a trolley jack...
coldel
I used a Large block of wood aswell to help spread load when doing brakes last weekend.
Then popped axle stands onto a bracing section rather than lower sills.
You may need to drive on to bricks and wood to do this method unless you have a low entry jack.
As per diagram above. Rear Diff or front member between the two plastic covers.
Don't use a trolley jack under the seal, you will crush/damage it.
If you have to use a trolley jack under the seal, put a couple of bits of wood either side of the seam or a block of wood with a groove cut in it to protect it and spread the load.
If your jack doesn't reach that far under then drive onto some blocks/bricks etc to raise the car a little then you should reach no bother.
Beat me to it. ;)
Im a bit of a noob at all this jacking up lark - so excuse the daft questions
I planned on picking up something similar to this
http://www.diy.com/nav/build/motoring-workshop-tools/access-lifting/trolley___car_jacks/Torq-5-piece-lifting-combo-kit-11227728
Pop a jack under the front centre, get it up, put the axle stands under the sides you say?
If that's the kind of jack I think it is, you'd be struggling to lift the front end. I have a 2.5 tonne Bradbury jack that I use which works well and looks something like this:
http://www.garageequipmentdirect.co.uk/ ... jacks.html
I have to use the Zed's scissor jack to get it high enough to get the Bradbury under though.
:thumbs:
