2 Questions
monkfish
Couple of questions someone can hopefully answer for me.......
1) Is the stock exhaust stainless or high grade steel? i.e will you be looking at replacing it due to corrosion in the car's early life?
2) Does the zed have a timing belt that will need replacing after x-amount of miles? I seem to recall someone saying it didn't have a cam belt?...
Cheers :blush:
1) Is the stock exhaust stainless or high grade steel? i.e will you be looking at replacing it due to corrosion in the car's early life? highish grade not stainless as some require replacement now
2) Does the zed have a timing belt that will need replacing after x-amount of miles? I seem to recall someone saying it didn't have a cam belt?... no cam belt on Zed .]cam chain valve timing
.cam chain valve timing
Cheers :blush:
