sidelights
sinbad
After seeing Val's sidelights at the North West Run back in October i've finally gone and bought some replacement sidelight bulbs from Funkystyling (who were great may i add).
How the hell do i fit them??? :surrender::scare:
Do i need to take the headlight out?
I kinda didn't even think about it when i ordered them...Doh!
You don't need to take the headlight out, but it ain't a 5 minute job:
-Remove wheel
-Remove plastic trim on front side (you can leave the rear side unless you want to change the blinker bulb on the side of the car). This is hold up with screws and the plastic clips, see attached picture.
-You have now access to the back of your headlight where you can twist the bulb out and replace it. For high beam you have to remove the round blue cover which is a PITA to put back.
