Jez @ H-Dev Posted February 20, 2012 Share Posted February 20, 2012 We're going to run a group buy on the D1 Spec 7-drive throttle controllers. These controllers allow you change the accelerator pedal to throttle plate ratio. The D1 SPEC 7-Drive allows you to set it in 3 modes: Sport, economy and standard. Sport mode has 7 different settings allowing you to fine tune throttle response. Economy mode has 5 settings that are designed to minimise fuel consumption. Standard mode is the normal setting, as if the controller is not connected The unit is plug and play - fitting is very simple, just unplug the throttle pedal connector and connect the 7-Drive inbetween. These are usually £119.99, in the group buy we can do them at these prices: 2+ - £99.99 4+ - £89.99 7+ - £79.99 Shipping with in the UK is £4.59 We will run the group buy until the 2nd March, so get your name down if you're interested 1. 2. 3. 4. 5. 6. 7. We will ship from the 2nd March onwards Quote Link to comment Share on other sites More sharing options...
JT350GT4 Posted February 20, 2012 Share Posted February 20, 2012 Is there any benefit to these if you've had an Uprev? Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted February 20, 2012 Author Share Posted February 20, 2012 Yes - you can still use these with Uprev and use the controllers different modes to change the throttle response Quote Link to comment Share on other sites More sharing options...
sparky370z Posted February 20, 2012 Share Posted February 20, 2012 i have literally just fitted one of these. its a great bit of kit. especially for those that havent had a Up-rev. SP7 is like getting a massive kick up the arse. ECO really tames the beast at low throttle position. will be good to see what its like on a long journey! recommend to everyone for Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted February 20, 2012 Author Share Posted February 20, 2012 Thanks for the recommendation To help the group buy it'd be great if people could add this to their signature - it'll help raise awareness and reduce the price for everyone [url=http://www.350z-uk.com/forum/viewtopic.php?f=161&t=58706][img=http://www.h-dev.co.uk/images/350z-uk/group buy.jpg][/url] Quote Link to comment Share on other sites More sharing options...
Karlp Posted February 20, 2012 Share Posted February 20, 2012 How well do these work with autos?? Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted February 20, 2012 Author Share Posted February 20, 2012 They'll work in exactly the same way as with a manual Quote Link to comment Share on other sites More sharing options...
Karlp Posted February 20, 2012 Share Posted February 20, 2012 Thanks Dude, will have a think Quote Link to comment Share on other sites More sharing options...
jumping350 Posted February 20, 2012 Share Posted February 20, 2012 great deal there!! ive got one of these and is by far one of the best mods ive done on the car Quote Link to comment Share on other sites More sharing options...
John tarantula Posted February 20, 2012 Share Posted February 20, 2012 ah want one of these but my OBD port is missing/cut off/fallen into the dash Quote Link to comment Share on other sites More sharing options...
jumping350 Posted February 20, 2012 Share Posted February 20, 2012 ah want one of these but my OBD port is missing/cut off/fallen into the dash Thats not good news..take your bottom dash apart and try fish it out Quote Link to comment Share on other sites More sharing options...
John tarantula Posted February 20, 2012 Share Posted February 20, 2012 had a vague look in there with a torch but couldn't see anything obvious dangling or taped up. Need to summon the strength to get it all out and crouch at an uncomfortable angle while looking for it. Quite tempted to get one of these D1 anyway so it gives me incentive to get it sorted! Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted February 20, 2012 Author Share Posted February 20, 2012 You don't need an OBD port - it plugs into the throttle pedal sensor Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 20, 2012 Share Posted February 20, 2012 You don't need an OBD port - it plugs into the throttle pedal sensor Unless they have changed significantly from the old model (not just looks) then they plug into the throttle pedal sensor AND the OBDII port Also on your site you say they are 350z & 370z but I thought they didn't even work with an HR 350z let alone a 370z I am an idiot so I may well be wrong Fantastic price though Quote Link to comment Share on other sites More sharing options...
JoshThePonce Posted February 20, 2012 Share Posted February 20, 2012 Very tempting indeed... Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted February 20, 2012 Author Share Posted February 20, 2012 Unless they have changed significantly from the old model (not just looks) then they plug into the throttle pedal sensor AND the OBDII port Also on your site you say they are 350z & 370z but I thought they didn't even work with an HR 350z let alone a 370z I stand corrected - they need the obd port and the pedal sensor You are probably right about the HR engined cars - I was told they'd work with the 370Z, but I will clarify asap. Thanks for setting me straight Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted February 20, 2012 Author Share Posted February 20, 2012 Very tempting indeed... Put your name down - you know you want to Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 20, 2012 Share Posted February 20, 2012 Unless they have changed significantly from the old model (not just looks) then they plug into the throttle pedal sensor AND the OBDII port Also on your site you say they are 350z & 370z but I thought they didn't even work with an HR 350z let alone a 370z I stand corrected - they need the obd port and the pedal sensor You are probably right about the HR engined cars - I was told they'd work with the 370Z, but I will clarify asap. Thanks for setting me straight No worries, I had the V2 version and loved it As I said a steal at the group buy prices, I sold mine 2nd hand over a year ago for nearly £100... Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 20, 2012 Share Posted February 20, 2012 OBD port I think is only for power, so technically you could take a feed from an ACC power source instead. Quote Link to comment Share on other sites More sharing options...
glenn-350 Posted February 20, 2012 Share Posted February 20, 2012 count me in please 1. Glenn-350z 2. 3. 4. 5. 6. 7. Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted February 21, 2012 Author Share Posted February 21, 2012 Thanks Glenn - hopefully we can get to 7+ and price down to £79.99 1. Glenn-350z 2. 3. 4. 5. 6. 7. Quote Link to comment Share on other sites More sharing options...
glenn-350 Posted February 21, 2012 Share Posted February 21, 2012 Jez, that would be good. keep me updated Quote Link to comment Share on other sites More sharing options...
Freebird Posted February 21, 2012 Share Posted February 21, 2012 100% in for the 7+ price Quote Link to comment Share on other sites More sharing options...
adymi16 Posted February 21, 2012 Share Posted February 21, 2012 Hi Jez, please put me down for one, i go on holdiay at the end of this week untill the 6th march, so will be offline till then, Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted February 21, 2012 Author Share Posted February 21, 2012 We're down to £99.99 - only 1 more person needed to get to £89.99 1. Glenn-350z 2. Freebird (+7 price) 3. Adymi16 4. 5. 6. 7. Quote Link to comment Share on other sites More sharing options...
