sasha@lazytrips Posted February 21, 2012 Share Posted February 21, 2012 Thanks bud, the GFX card was recommened in PC Format and when i looked online it seemed to get a bit of a hammering when it was full price but now its dropped it seems to get very good feedback, for the price. One other thing is this: I am probably quite different to most people, but for most people's usage, one decent top-end card will cover all their needs for quite some time. I bought what was a pretty decent (almost top of the range) card at the time with the intention on buying an identical (but much much cheaper) card in 2-3 years time to get a huge boost in performance for virtually no outlay. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 21, 2012 Share Posted February 21, 2012 My next upgrade will be a new graphics card.... Not done a massive amount of research but I going on budget I am looking at either a GTX 470 or a GTX 560 TI, doesn't seem to be a huge difference 470 is slightly better and slightly more expensive... Neither are the best in any shape or form but I would rather have a good compromise between price and performance than having my pants pulled down for the latest card... Quote Link to comment Share on other sites More sharing options...
BulletMagnet Posted February 21, 2012 Share Posted February 21, 2012 My next upgrade will be a new graphics card.... Not done a massive amount of research but I going on budget I am looking at either a GTX 470 or a GTX 560 TI, doesn't seem to be a huge difference 470 is slightly better and slightly more expensive... Neither are the best in any shape or form but I would rather have a good compromise between price and performance than having my pants pulled down for the latest card... If it helps, I have a GTX 470 currently, an EVGA Superclocked HydroCopper version (comes with a waterblock fitted already). Have had no issues with it at all and after having it for more than a year, it still performs quite well. Only gripe I have is that you can only use the hose fittings provided as the threading on the waterblock are not the standard BSP 1/4 type usually used by waterblock manufacturers. In comparison, my friend has a 6850 Eyefinity and is running a triple monitor setup for gaming and it's pretty lush, but perhaps overkill if you only intend to run off one monitor. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 21, 2012 Share Posted February 21, 2012 Cheers BM, I know I should really stretch it to get a GTX 470 but not sure I would get the use from it and notice the difference from a GTX 560 TI which would probably be about £50-60 cheaper Quote Link to comment Share on other sites More sharing options...
neo-ninja Posted July 18, 2012 Author Share Posted July 18, 2012 So thought i would update this, in the end i ended up spending about £200 over my budget but it should be a much better pc and hopefully last longer in theory Ivybridge i5 3570k processor Corsair water cooler 8gb 1600mhz gaming ram ATI HD 6850 1gb gfx card 128 samsung ssd then i reused my old dvd wr and hdd drives So far it boots windows 7 pro from a cold start in under 18s! which is insane! thanks for the adviced all Quote Link to comment Share on other sites More sharing options...
