help front suspension problem
racinggreen
I'm guessing its just the picture but the nearside wheel appears to be set further forward than the off side. Might be worth clarifying they are both in line to rule that out as part of the problem.
If they are even then check to make sure you haven't got a broken spring on the off side before anything
  • 3 months later...
If they are even then check to make sure you haven't got a broken car suspensions on the off side before anything
my front suspension feels very loose and i can hear like a joint knocking sound when driving!
the car is lowered but the ride feels harsher now
does anyone know if this could be the wishbone or track rod ends?
