Test Pipes
captint
Guest prescience
No cats hence less restricted flow and with the engine being in essence a pump, in theory more power (but with the Z's ECU ......). Will also be much louder and non-resonated sound very raspy.
Will also need a method (non-foulers) of 'fooling' the 02 sensors because otherwise you will get a CEL due to the exhaust gas chemistry.
No point N/A, little point S/C and good benefit ST or TT
Guest prescience
  Stew said:
So is this like decat pipes then?
They are one and the same :teeth:
They are illegal and will fail the MoT emissions test.
For S/C, HF cats are perfect, a little bit of back pressure helps IMO, for ST/TT you want to minimise back pressure altogether so HF with ST/TT is not a great option - could tip a borderline tune over the edge
