Urgent help!
ArsenalMoh
Hi guys,
I'm sitting at a Nissan Dealership and after a test drive and everything, the only sticking point is full Bluetooth compatibility.
Right now, I'm not getting a 'Phone' option in my settings menu & therefore my address book, recent calls etc aren't being sync'd.
I can receive a call through the speakers as normal though.
Does anyone have any knowledge of why I don't have a phone option in my settings menu?
It's a 57 plate Zed and I have an iPhone 4.
Urgent responses would really be appreciated!
If your BT on your phone is enabled it should find the car. You might need to switch the ignition off and on again. The contacts sync is a PITA, as far as I remember you have to enter each one manually for the voice dialling to work. I started to look at it but then got bored and gave up......
there is no syncing of address book. Any numbers you wish to store on the bluetooth are input by voice command. The bluetooth can make and receive calls and I think have ten stored numbers with names, and you have a redial option. Think thats a rough outline
If you go to guides you will find the manual for the bluetooth on this forum
