drysd4le Posted February 9, 2012 Share Posted February 9, 2012 hi i am looking for a pair of boot release springs for a 2003 350z, mine have broken lugs and are just not opening the boot anymore, just fitted new gas struts from sgs which are perfect but my springs are shot!! any help would be great. cheers Quote Link to comment Share on other sites More sharing options...
ChrisS Posted February 9, 2012 Share Posted February 9, 2012 Quote Link to comment Share on other sites More sharing options...
drysd4le Posted February 9, 2012 Author Share Posted February 9, 2012 already have just awaiting reply and thought i'd see if anyone else could help just in case. cheers Quote Link to comment Share on other sites More sharing options...
bkjmr Posted February 9, 2012 Share Posted February 9, 2012 http://www.350zmotoring.com/forums/diy-garage/18920-rear-hatch-opening-fix-how.html I just did this and it seemed to have worked. Only opened boot about 5 times to test it. Previously my boot wouldn't open unless i pressed the button and lifted it up. Only costs 4p too. I used a vice to put the boot over the spring as it is a bit niggly otherwise. Quote Link to comment Share on other sites More sharing options...
brumjohn Posted February 9, 2012 Share Posted February 9, 2012 think theyre about £37-40 quid each plus postage. Your local nisssan dealer can source for a very similar figure and you may save postage, but they are unlikely to have them in stock, support your forum traders where poss. Quote Link to comment Share on other sites More sharing options...
Hennerz Posted February 9, 2012 Share Posted February 9, 2012 Going to try this when i get home Quote Link to comment Share on other sites More sharing options...
drysd4le Posted February 9, 2012 Author Share Posted February 9, 2012 was gonna try the penny trick but the part that has broken is the little lug that holds it in place to the body so the whole unit is useless cheers though Quote Link to comment Share on other sites More sharing options...
Hennerz Posted February 9, 2012 Share Posted February 9, 2012 http://www.350zmotoring.com/forums/diy-garage/18920-rear-hatch-opening-fix-how.html I just did this and it seemed to have worked. Only opened boot about 5 times to test it. Previously my boot wouldn't open unless i pressed the button and lifted it up. Only costs 4p too. I used a vice to put the boot over the spring as it is a bit niggly otherwise. Silly question i know, but is it best to put 2 1p in each one? Quote Link to comment Share on other sites More sharing options...
ChrisS Posted February 9, 2012 Share Posted February 9, 2012 Think someone used tap washers. Quote Link to comment Share on other sites More sharing options...
bkjmr Posted February 9, 2012 Share Posted February 9, 2012 http://www.350zmotoring.com/forums/diy-garage/18920-rear-hatch-opening-fix-how.html I just did this and it seemed to have worked. Only opened boot about 5 times to test it. Previously my boot wouldn't open unless i pressed the button and lifted it up. Only costs 4p too. I used a vice to put the boot over the spring as it is a bit niggly otherwise. Silly question i know, but is it best to put 2 1p in each one? I put 2 x 1p's in there. Quote Link to comment Share on other sites More sharing options...
Hennerz Posted February 9, 2012 Share Posted February 9, 2012 http://www.350zmotoring.com/forums/diy-garage/18920-rear-hatch-opening-fix-how.html I just did this and it seemed to have worked. Only opened boot about 5 times to test it. Previously my boot wouldn't open unless i pressed the button and lifted it up. Only costs 4p too. I used a vice to put the boot over the spring as it is a bit niggly otherwise. Silly question i know, but is it best to put 2 1p in each one? I put 2 x 1p's in there. Cheers mate, hope it work Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 9, 2012 Share Posted February 9, 2012 Pm received and replied to In stock and good to go same/next day Alex. Quote Link to comment Share on other sites More sharing options...
cmck13 Posted February 10, 2012 Share Posted February 10, 2012 Think someone used tap washers. It was me and I thought it was better because steel washers, money, etc wear through the rubber boot and and start eating into the bodywork. a couple of small tap washers work well. Quote Link to comment Share on other sites More sharing options...
