Shinjuku Posted February 4, 2012 Share Posted February 4, 2012 I see that using a pop charger results in a slight loss in power due to heat soak from the engine. Is there a way to duct some air into that area. Standard car. Dont want to cut too many holes particularly where they can be seen. Thanks Shinjuku Quote Link to comment Share on other sites More sharing options...
HassanZ Posted February 4, 2012 Share Posted February 4, 2012 I will be following this thread as I am trying to find a solution without cutting a hole into my front bumper also. I was trying to source a longer pipe which can replace the stock pipe the pop charger is fitted to, that would bring the filter further away from the engine and closer to the front bumper. I have so far been unsuccessful... Quote Link to comment Share on other sites More sharing options...
kiingsi Posted February 4, 2012 Share Posted February 4, 2012 I think this is custom made but you want something along the lines of this http://www.z1motorsports.com/imageGallery/main.php/v/Z1Cars/album189/ValidationKit_Photography195.JPG.html Have you tried AEM I think they do a long one but not sure, never seen one fitted. Quote Link to comment Share on other sites More sharing options...
Shinjuku Posted February 4, 2012 Author Share Posted February 4, 2012 To be honest I would like to look at the ducting option rather than remoting the unit itself - although I recognise that as a good solution. Has anyone done this. Quote Link to comment Share on other sites More sharing options...
leodspider Posted February 4, 2012 Share Posted February 4, 2012 The unit Kiingsi posted is a momentum performance unit, which i currently have ( only one in the uk i believe ). Unfortunately you cant get them any more unless second hand, as they've closed up the company . you could always use hoses to direct the air, just hide them so that cant be seen Quote Link to comment Share on other sites More sharing options...
kiingsi Posted February 4, 2012 Share Posted February 4, 2012 You lucky bugger lol id love one I new i'd found it somewhere. Is momentum closed? they seemed to do some good stuff for the zed Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 4, 2012 Share Posted February 4, 2012 Get down Halfrauds, buy some ducting and then route it around the crash bar. Its pretty easy to find the route when you go out and have a poke around, making sure you remove the poppers on the front pn the bumper to pull it forward a bit. On the bumper, at either end of the slats in the middle, there are sections you can remove with poppers like the bumper has to remove it. Pop out the one on the right (looking from the front) and secure the pipe in that area with the poppers you just removed. Thats what I did. Dont have any pics I dont think, but its pretty obvious once you start Quote Link to comment Share on other sites More sharing options...
kiingsi Posted February 4, 2012 Share Posted February 4, 2012 Think ill give it a go after the snow when i change my headlight bulbs Cheers Quote Link to comment Share on other sites More sharing options...
HassanZ Posted February 4, 2012 Share Posted February 4, 2012 Get down Halfrauds, buy some ducting and then route it around the crash bar. Its pretty easy to find the route when you go out and have a poke around, making sure you remove the poppers on the front pn the bumper to pull it forward a bit. On the bumper, at either end of the slats in the middle, there are sections you can remove with poppers like the bumper has to remove it. Pop out the one on the right (looking from the front) and secure the pipe in that area with the poppers you just removed. Thats what I did. Dont have any pics I dont think, but its pretty obvious once you start Did the ducting make any noticeable difference? Quote Link to comment Share on other sites More sharing options...
Chris`I Posted February 4, 2012 Share Posted February 4, 2012 Did the ducting make any noticeable difference? Once moving it made maybe 1C difference if you're lucky. When stationary - not supprisingly - it made sod all difference. Where it did help was once you got moving again. With no ducting it could take a good minute or so for the intake temps to drop back to a few degrees above ambient. With the ducting it took about 30sec to get to the same place but dropped almost immediately to get there too. Get down Halfords and buy some, it costs less than a tenna, and give it a go Quote Link to comment Share on other sites More sharing options...
SteveW Posted February 4, 2012 Share Posted February 4, 2012 That's what I did then cut a round hole in the deflector and routed the pipe through that and behind the crash bar. Quote Link to comment Share on other sites More sharing options...
