Demolition49 Posted February 3, 2012 Share Posted February 3, 2012 Cars been sitting a while not been using her much in the winter want to get the Z all prepped up for the summer but im stuck with a couple of issues! Front brake pads are very low / need replacing, im guessing because of this my handbrake light is coming on while braking hardish, ive already checked the fluid and that seems fine, so am i correct in saying its the pads? Second issue is the TC (OFF) light keeps coming up and staying on if i brake hard Third issue is when cornering the oil light will come on momentarily untill the wheel has been straightened up again (this doesnt happen on every corner - usually when the wheel requires turning quite quickly it happens) Any ideas? Thanks guys, cant wait to get her back to 100% i do miss the Z! Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 3, 2012 Share Posted February 3, 2012 The oil light is coming on because you will be low on engine oil. A set of pads should fix at least one of your other issues. Alex. Quote Link to comment Share on other sites More sharing options...
Daryl Posted February 4, 2012 Share Posted February 4, 2012 Possible ABS sensor causing handbrake light etc. Quote Link to comment Share on other sites More sharing options...
elfman Posted February 4, 2012 Share Posted February 4, 2012 As alex says get some oil in her mate! Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 4, 2012 Share Posted February 4, 2012 I'm no expert but I would have thought the oil light coming on means you need some oil Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 4, 2012 Share Posted February 4, 2012 I'm no expert but I would have thought the oil light coming on means you need some oil Correct on both counts Dave Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 4, 2012 Share Posted February 4, 2012 I'm no expert but I would have thought the oil light coming on means you need some oil Correct on both counts Dave Thanks I think Quote Link to comment Share on other sites More sharing options...
