Aust350z Posted February 2, 2012 Share Posted February 2, 2012 Guys, I was wondering if you were able to help come up with another alternative for the below. I'm looking to install a "drive recorder" which also has a feature for motion and g-force recording (when car is turned off). One of the supporting accessories has a power pack that includes and on/off switch to compeltely turn the device off idealy when I'm safe and sound at home in my garage. What I was thinking was installing a VDC button to control this on/off feature in a more easily accessible place. I was thinking VDC can stand for "Vehicle Detective Control". Is anyone aware of any other Nissan button that might be appropriate for the below spot I'm also open to those options. Ideally I'd like something with a light so I knew if it were on or off which the VDC button doesn't have (or the pics I have don't show). Effectively I want to install the button here: so it looks like this when done: Cheers, Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted February 2, 2012 Share Posted February 2, 2012 Have a search for SpursMadDave's car audio thread, he has put a button in that same place for his motorised cubby Quote Link to comment Share on other sites More sharing options...
Aust350z Posted February 2, 2012 Author Share Posted February 2, 2012 Thanks. Found the thread(s). I'm confident of getting the wiring all working thought. What I'm after is an OEM looking button to use Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 2, 2012 Share Posted February 2, 2012 I did fit a switch there, it is out now as I had a slight accident with the motor I struggled to find one that fitted perfectly as i needed a push to make one in 2 directions, if yours is just on/off it might be easier. The centre tunnel comes out without too much hassle and the switch housing comes off. It you take the switches out mind the little spring that will fly out Is that a switch in your picture or just a cover? It looks a perfect fit to me but doesn't look like a switch, just the cover moved... If you find a perfect fitting switch please let me know Quote Link to comment Share on other sites More sharing options...
Aust350z Posted February 2, 2012 Author Share Posted February 2, 2012 Is that a switch in your picture or just a cover? It looks a perfect fit to me but doesn't look like a switch, just the cover moved... It's the original VDC button someone moved from the dash to there so they stopped opening the fuel filler cap. I'd be happy using it but I'd have no indication if it was on or off If you find a perfect fitting switch please let me know Absolutely EDIT: Thinking aloud - as my car doesn't have VDC (non-track) I wonder if the light on the Dash is there though? I could then wire the the switch to the dash so when I deactivate the recorder the light shows up? Will need to look into it and see. *Runs off to read service manuals* Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 2, 2012 Share Posted February 2, 2012 Anything is possible i guess a button from a wrecked car wouldn't be expensive.... Would you not power the recorder from the ignition so when the ignition is turned off it cuts the power? Quote Link to comment Share on other sites More sharing options...
Aust350z Posted February 2, 2012 Author Share Posted February 2, 2012 Anything is possible i guess a button from a wrecked car wouldn't be expensive.... Can grab a new one for pretty cheap which is OK. Would you not power the recorder from the ignition so when the ignition is turned off it cuts the power? No. The drive recorder still needs power to record via its "motion sensor" (ie: someone driving/walking past your car) and also "g-force" (ie: someone bumping your car). If one of these sensors goes off it records the previous 30secs and goes for an optional time frame after. Hence the power pack sold as an accessory is necessary to avoid draining your car battery. One version of the power pack has the over-riding on/off button so you can switch it completely off (ie: when the car is safely parked in your garage). The power pack will be hidden away hence why I'm looking for a button to replace it in a usable spot. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 2, 2012 Share Posted February 2, 2012 Ah now I understand On a UK car some of the switches are illuminated, I think the ESP on/off and the headlight wash button, you could try and fond one of these and get a vinyl overlay with whatever description you wanted.... I never thought of getting one of those and seeing if it fitted, yiu got me thinking now Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 2, 2012 Share Posted February 2, 2012 My last opportunity to show you my switch also, as it's being taken out the car tomorrow Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 2, 2012 Share Posted February 2, 2012 My last opportunity to show you my switch also, as it's being taken out the car tomorrow A little ostentatious for me Ian.... As you know I am very shy and retiring If I had a switch like that in my Zed I would expect it to fire a machine gun at the twonk in front of me at the toll looking for a £1 coin even though he has been on the M25 heading towards the toll for the last half an hour Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 2, 2012 Share Posted February 2, 2012 Ah ha if only. Had the same problem with a woman at the toll on Saturday, fiddling around for change, then went to her bag for a note, taking her time with repositioning her bag then giving the money over, then grabbing bag to put change returned to her back in her bag nicely. She was at the booth about 2/3 mins stoopid cow! Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 2, 2012 Share Posted February 2, 2012 Ah ha if only. Had the same problem with a woman at the toll on Saturday, fiddling around for change, then went to her bag for a note, taking her time with repositioning her bag then giving the money over, then grabbing bag to put change returned to her back in her bag nicely. She was at the booth about 2/3 mins stoopid cow! And that 2/3 minutes seems like a lifetime Only thing slightly more irritating is waiting at a petrol station, I mean open car door, start engine, engage gear, move.... how can that take more than a few seconds Quote Link to comment Share on other sites More sharing options...
R35LEE Posted February 2, 2012 Share Posted February 2, 2012 I have a load of OEM 350 switches. I think one of the jdm ones has no markings on it Quote Link to comment Share on other sites More sharing options...
Aust350z Posted February 2, 2012 Author Share Posted February 2, 2012 A little ostentatious for me Ian.... Me too unfortunately Not quite the OEM look I was going for. If I had a switch like that in my Zed I would expect it to fire a machine gun at the twonk in front of me at the toll looking for a £1 coin even though he has been on the M25 heading towards the toll for the last half an hour So want! So very want!! Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 2, 2012 Share Posted February 2, 2012 But people always say "ooooooh so what does that switch do?" Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 2, 2012 Share Posted February 2, 2012 But people always say "ooooooh so what does that switch do?" Do you tell them it is connected to the flux capacitor Quote Link to comment Share on other sites More sharing options...
Wasso Posted February 2, 2012 Share Posted February 2, 2012 But people always say "ooooooh so what does that switch do?" Do you tell them it is connected to the flux capacitor No it breaks spark plugs Or I say it's the ejector seat switch. Quote Link to comment Share on other sites More sharing options...
bronzee Posted February 3, 2012 Share Posted February 3, 2012 Being that what's marketed in Auz is very similar to Kiwiland, what about a Maxima, Murano or Pulsar button etc?? From a wreckers, and then get it stickered with whatever you need. Some like that must be fairly generic. Quote Link to comment Share on other sites More sharing options...
Aust350z Posted February 3, 2012 Author Share Posted February 3, 2012 Just check and no VDC light on the dash I could tap into. Only have a TCS off and SLIP Being that what's marketed in Auz is very similar to Kiwiland, what about a Maxima, Murano or Pulsar button etc?? From a wreckers, and then get it stickered with whatever you need. Some like that must be fairly generic. Just want something with a built in light that looks OEM. I guess I need to start trawling through Google images.. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 6, 2012 Share Posted February 6, 2012 Good luck with the search Quote Link to comment Share on other sites More sharing options...
Aust350z Posted February 6, 2012 Author Share Posted February 6, 2012 Currently the stock fog light form a 370z is leading the way... updated seat heater switches look nice too In other news - I found a Nissan button with receiver to use as my TPMS monitor Includes harness for OE install. Reading the manual there is a PSI version and audio alerts too. In further new I stumbled across pics of the Footwell lamps (B6400-CD000) and Interior Illumination Kit (under dash lights). Want want want. Anyone know where to get them!!?? Quote Link to comment Share on other sites More sharing options...
MidnightRacer Posted February 6, 2012 Share Posted February 6, 2012 what where how any why information on that TPM Switch please!!!!!!! Quote Link to comment Share on other sites More sharing options...
Aust350z Posted February 6, 2012 Author Share Posted February 6, 2012 what where how any why information on that TPM Switch please!!!!!!! I've found the Chinese manufacturer and have asked for more info Hopefully can get my hands on a sample/trial unit. Owners Manual http://www.inawise.com/nissan/nissan-li ... manual.pdf Installation Manual http://www.inawise.com/nissan/nissan-li ... manual.pdf I currently have an Orange TPMS system in the car and have been struggling to work out where to steathy install the display. I ended up deciding on the sunglass holder and running a wire through the a-pillar and headliner. I think this little unit should (in theory) work with my sensors already so should give me an even steathier install and OEM looking TPMS. http://www.orangetpmsusa.com/aftermarke ... ar-tpms-2/ Quote Link to comment Share on other sites More sharing options...
