HassanZ Posted January 29, 2012 Share Posted January 29, 2012 Hi all, Recently I've noticed a really high pitched squeaky noise coming from somewhere when I drive over an uneven road. I'm trying to work out if it's interior or suspension related but I'm finding it difficult to tell! Do the seats or seat belt clips suffer from this if they're not greased enough? Is there something I should check first that's common on other 350z's? I appreciate your help guys! Hassan Quote Link to comment Share on other sites More sharing options...
Zugara Posted January 29, 2012 Share Posted January 29, 2012 Lube up the rubber bungs on your doors and boot lid. Failing that lube your drop links and associated rear suspension bushes Quote Link to comment Share on other sites More sharing options...
Ryan Posted January 29, 2012 Share Posted January 29, 2012 +1 on the suspension bushes!! i've found it hard to pin point a squeeky bush on other cars, so just end up spraying lube over all of them. Quote Link to comment Share on other sites More sharing options...
HassanZ Posted January 29, 2012 Author Share Posted January 29, 2012 I'm sorry but this is going to sound really dumb....can someone please show me a pic of exactly what to lubricate? Quote Link to comment Share on other sites More sharing options...
PeteDench Posted January 29, 2012 Share Posted January 29, 2012 try the knee pad on the passenger side, this sqeeks on mine . if you get somebody to push it slightly and the noise stops then you have found the problem. it will need packing out from behind Quote Link to comment Share on other sites More sharing options...
Zugara Posted January 29, 2012 Share Posted January 29, 2012 open the doors, and near the top on the inside of the door, you will see a black rubber bung. same in the boot lid. anything on the rear suspension that can move, lube it. Get under the rear end and you wlll see the bushes quite clearly, dont forget the droplinks also need a drink too. Quote Link to comment Share on other sites More sharing options...
HassanZ Posted January 29, 2012 Author Share Posted January 29, 2012 Thanks mate, ill get on it. Is Castrol LM Grease okay to use? I've got a tub of it sitting in the garage... Quote Link to comment Share on other sites More sharing options...
Zugara Posted January 29, 2012 Share Posted January 29, 2012 LM ok for door bungs,only a smear required on these mate, you gonna need spray grease for the suspension. Thanks mate, ill get on it. Is Castrol LM Grease okay to use? I've got a tub of it sitting in the garage... Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted January 30, 2012 Share Posted January 30, 2012 would WD40 do, or is there a better solution? Quote Link to comment Share on other sites More sharing options...
Zugara Posted January 31, 2012 Share Posted January 31, 2012 On the doors nope, you need silicone grease or similar. WD doesnt have the life span od grease, and gets washed away quicker. But you could try, no harm done IMO would WD40 do, or is there a better solution? Quote Link to comment Share on other sites More sharing options...
Dblock Posted January 31, 2012 Share Posted January 31, 2012 would WD40 do, or is there a better solution? WD40 isnt any good IMO. Its only a water displacer. Get some spray grease or ferrosol. Quote Link to comment Share on other sites More sharing options...
DaddyCee Posted February 3, 2012 Share Posted February 3, 2012 ok will do. what's a good spray grease to look at? Quote Link to comment Share on other sites More sharing options...
Zugara Posted February 3, 2012 Share Posted February 3, 2012 ok will do. what's a good spray grease to look at? Go to halfords, you can get spray grease there in a blue n yellow aerosol can, that's what I use, good stuff IMO. Quote Link to comment Share on other sites More sharing options...
Dblock Posted February 3, 2012 Share Posted February 3, 2012 ok will do. what's a good spray grease to look at? I just get it from the internet alot cheaper. Any spray grease will be fine TBH. If you do want to buy local phone your local autosmart rep Quote Link to comment Share on other sites More sharing options...
stubzie83 Posted February 4, 2012 Share Posted February 4, 2012 My driver's seat squeaks over bumps. It seems to come from the left hand side as it sometimes squeaks when I'm stationary and pushing the clutch pedal i.e. pushing on the left side of the seat by moving left leg on the clutch. I think it might be the leather moving around the seat adjustment switches. I think my centre console/knee pads also squeak a bit over uneven ground as well Quote Link to comment Share on other sites More sharing options...
Zugara Posted February 4, 2012 Share Posted February 4, 2012 Move your seat forward a bit. Bet its rubbing on something. My driver's seat squeaks over bumps. It seems to come from the left hand side as it sometimes squeaks when I'm stationary and pushing the clutch pedal i.e. pushing on the left side of the seat by moving left leg on the clutch. I think it might be the leather moving around the seat adjustment switches. I think my centre console/knee pads also squeak a bit over uneven ground as well Quote Link to comment Share on other sites More sharing options...
elfman Posted February 4, 2012 Share Posted February 4, 2012 Move your seat forward a bit. Bet its rubbing on something. My driver's seat squeaks over bumps. It seems to come from the left hand side as it sometimes squeaks when I'm stationary and pushing the clutch pedal i.e. pushing on the left side of the seat by moving left leg on the clutch. I think it might be the leather moving around the seat adjustment switches. I think my centre console/knee pads also squeak a bit over uneven ground as well +1 Maybe you have a mouse caught somewhere? That's what my mrs says about my breaks and other squeeky bits Quote Link to comment Share on other sites More sharing options...
