chrisgunton Posted January 24, 2012 Share Posted January 24, 2012 Bit puzzled by this as I'm used to it being the other way round (squealing when starting). Late last year when it had a full service I had the belt changed. It squealed on damp mornings, and I ended up going back to the garage to have it tightened a couple more times. The garage was reluctant to tighten it any more than it is. Now it's started squealing at 3k rpm and up while driving. Tighten it some more? Quote Link to comment Share on other sites More sharing options...
tprice Posted January 25, 2012 Share Posted January 25, 2012 try puttin some chalk in the grooves how tight is the belt now, can you twist it 90degrees? Quote Link to comment Share on other sites More sharing options...
chrisgunton Posted January 26, 2012 Author Share Posted January 26, 2012 About 70 degree, tight enough? Quote Link to comment Share on other sites More sharing options...
chrisgunton Posted January 27, 2012 Author Share Posted January 27, 2012 No one? Quote Link to comment Share on other sites More sharing options...
Dblock Posted January 28, 2012 Share Posted January 28, 2012 Mine does this but it needs tightened and I'm chafing the pulleys soon. You got the right size belt? Quote Link to comment Share on other sites More sharing options...
chrisgunton Posted January 28, 2012 Author Share Posted January 28, 2012 Yeah I got the belts from Zmanalex (of course!). I don't know if they are tight enough, or even if it's ok to thrash it. I would have thought squealing = slipping = friction = heat = possibly snapping them. Quote Link to comment Share on other sites More sharing options...
Dblock Posted January 28, 2012 Share Posted January 28, 2012 Yeah because the power isnt going through the belts but on them. You could try it yourself, ask a member near you or take it to another garage. Quote Link to comment Share on other sites More sharing options...
chrisgunton Posted January 28, 2012 Author Share Posted January 28, 2012 So how much should I be able to twist the belts? Last thing I want to do is over-tighten them and put strain elsewhere. Quote Link to comment Share on other sites More sharing options...
Dblock Posted January 28, 2012 Share Posted January 28, 2012 Its the tensioner that moves in and out. I don't think you can have a belt too tight unless it doesn't turn? Could be wrong though. Quote Link to comment Share on other sites More sharing options...
elfman Posted January 28, 2012 Share Posted January 28, 2012 the way to test it is if you press down on the belt with your thumb it shouldn't move down more than 4cm if i remember correctly if you have any trouble there's a guide in the guide section Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 28, 2012 Share Posted January 28, 2012 of course Quote Link to comment Share on other sites More sharing options...
Chris`I Posted January 28, 2012 Share Posted January 28, 2012 Its also in the service manual under Engine > Mechanical - http://www.nicoclub.com/FSM/350Z/ Quote Link to comment Share on other sites More sharing options...
