glrnet Posted January 23, 2012 Share Posted January 23, 2012 Thought I'd post this up and hopefully it will help other who want to replace their nipples (bleed valves). I took one of the nipples out of the front and rear BREMBO calipers, (they are the same) and photographed it against a ruler but for clarification the sizes are as follows:- Overall length 30mm Length in caliper body 17mm Diameter 10mm Nut size 11mm These measurement are as accurate as they can possibly be using the naked eye and I accept no responsibility for inaccuracies. This is a guide only. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted January 23, 2012 Share Posted January 23, 2012 Cheers Papa you are indeed a star I am still going to pop to a local place and get them to check on their system or worse case remove the one good rear one and measure it as well. I will post up when I am sorted in case anyone else has the same issue Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted February 3, 2012 Share Posted February 3, 2012 Sorry nipples excite me Supplied by ZManAlex of course 1 Quote Link to comment Share on other sites More sharing options...
