Bluetooth Language..
adam1942
Hi folks..
I finally got a Nissan 350z which ticks all the boxes(a member from on here Seanybaby's). I'm having a little trouble with the bluetooth connectivity..
It seems the bluetooth has been set to France language.. so when I talk to it - it says something I don't know.. It obviously also does not understand me.. Can anyone tell me how to change this? I cant seem to find it anywhere :(
Cheers guys!
Adam.
On a 350z you can't change language through settings. The phone module is inside of the cubby / glovebox behind the passenger seat. You lift the mat and will need a flat head screwdriver to lift the plastic tray out. The module is double sided foam stuck to the underside of the tray. I have UK speaking modules in the garage
Cheers folks! I was gutted when I realised - the phone works if I answer it I just cant use voice controls.. It was quite funny though just kinda sat there going.. what just happened ?! heh!
R35Lee - I just found an old forum post from 2009 in which a user had this same issue and noticed you had posted! (I wonder if this is the unit the other user had?!) anyway I've pmed you for a price etc!
Thanks again folks!
vous savez ce que je voulais dire, Jim, pas besoin d'être un âne futé. dit en plaisantant selon les règles Miltek et l'amour de Brokeback Mountain.
All I can see is Brokeback mountain - Should I translate it? :p
Probably only if you want to be arrested! :scare:
