Hennerz Posted January 20, 2012 Share Posted January 20, 2012 I know this may have been talked about before but new hear and still trying to get my head around the forum. When i go to put the window up you can hold the button or pull it up once and the window closes its self, but when i do so the window goes up and then drops about 3 inches, and if it really want to annoy me it does it when i close the door I have had this problem since I brought the car and some times it works and sometimes it doesn't Does anyone know what the problem is and how i can fix it? Thanks, Henry Quote Link to comment Share on other sites More sharing options...
Keyser Posted January 20, 2012 Share Posted January 20, 2012 Windoe reset guide here viewtopic.php?f=35&t=141 may help Quote Link to comment Share on other sites More sharing options...
Hennerz Posted January 20, 2012 Author Share Posted January 20, 2012 thanks Next silly question, how do you remove the door panel? Quote Link to comment Share on other sites More sharing options...
DannyBoy Posted January 20, 2012 Share Posted January 20, 2012 thanks Next silly question, how do you remove the door panel? It pops off around the bottom and sides and then it's sort of hooked on at the top so just lifts off. But you'll need to take the window switch cover off first which just has one screw in the handle recess and then pulls off. It's all pretty intuitive if you just take your time and think about what you're doing. DB Ps. electrical tape on a flathead screwdriver=trim removal tool Quote Link to comment Share on other sites More sharing options...
Keyser Posted January 20, 2012 Share Posted January 20, 2012 2 screws behind the switches and 1 behind the inner door handle plastic guide hear http://liljerk.morpheus.net/350Z/front_speakers/ dare I say - Search is your friend? Quote Link to comment Share on other sites More sharing options...
