Need a New Clutch
Hennerz
Hi Guys,
My clutch is now starting to slip pretty badly and after looking at a couple of threads contacted Japex, which are reasonably close to me.
They said they can get an exedy clutch and a LUK dual mass flywheel, are these any good?
Was also wondering what upgrades I could get that are not going to cost too much? And if i was to upgrade would i have to inform my insurance company?
Thanks,
Henry
:pmzmanalex: for parts, might be able to get a better deal - he has both exedy and luk
Exedy and luk dual mass are the standard replacement parts...I used the same for mine. You can upgrade to a lighter flywheel and some of the guys on here have - they reported better rev response on the plus side and a bit more gearbox noise on the minus side.
Pretty sure someone on here will also comment.
Exedy Clutch kits and LUK OEM dual mass flywheels in stock.
Also single mass aluminium lightened flys in stock as well.
All good to go same/next day :thumbs:
Drop me a pm if I can help you further :thumbs:
Alex. :)
Hi Alex,
Will send you a PM in a bit :)
Go for the flywheel, if your clutch is slipping then its already too late to save the current one - get the garage to show you the old one you should see some marks burned into it. In any case its worth changing at the same time because if the flywheel lets go in a few thousand miles you have to pay out the labour again to replace it seperately from the clutch.
