bazmcc Posted January 17, 2012 Share Posted January 17, 2012 Just looking for some advice on motorised cubby lids. My 04 JDM had a motorised lid on the Jap nav unit, which I managed to break when removing the unit to send to Nurrish to have his system fitted. I could still use the unit but couldn't close the lid. I'm now selling the unit which another member is interested in buying, but his JDM import didn't have a motorised cubby lid to begin with. Is there any way for him to be able to get power to the lid easily? I assume that cars without the motorised lid come without the whole section behind the triple gauge cluster? (Cable from somewhere behind dash plugs into white box which is attached to rear of triple gauge cluster. From this white box a ribbon cable attaches to the lid) Can anyone shed any more light for me, or come up with a possible solution to get power to the lid? Quote Link to comment Share on other sites More sharing options...
glrnet Posted January 17, 2012 Share Posted January 17, 2012 PM spursmaddave, he's done this I think Quote Link to comment Share on other sites More sharing options...
bazmcc Posted January 17, 2012 Author Share Posted January 17, 2012 thanks Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted January 17, 2012 Share Posted January 17, 2012 All I did was manually run the motor from a 12v battery. You need to be able to switch the polarity to go one way and then the other so you need a dpst 3 way rocker switch so you can have off and on in each polarity. I stuffed my motor up and need to resolder it so mine is back to manual now anyway, I wouldn't recommend trying to do this it is a complete PITA to be honest.... If you want to try it out then get a little 12v battery, or a 9v one will work but slower and connect it to the motor you will see if the motor works I have no idea about all the actual jap satnav wiring as mine never had any of this Hope thats some small help This shows that it can be done at least http://www.350z-uk.com/forum/viewtopic.php?f=27&t=54590&hilit=motorised+cubby Quote Link to comment Share on other sites More sharing options...
bazmcc Posted January 17, 2012 Author Share Posted January 17, 2012 Brilliant, cheers. I came across this not long after posting pm'ing you, I'll pass the info on to the interested party Quote Link to comment Share on other sites More sharing options...
bazmcc Posted January 17, 2012 Author Share Posted January 17, 2012 Would the other option be to free Nurrish's unit from the surround and fit to the non-motorised unit? Guessing that would be easier... Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted January 17, 2012 Share Posted January 17, 2012 It most certainly would Or you can remove the motor mechanism amd the cubby will just lift up and down, thats how i have mine at the moment until i can be bothered to rewire it.... The actual little motor has a few screws holing it in, remove all those take the motor out and away you go Quote Link to comment Share on other sites More sharing options...
