HKS Braided Line Fitment
coldel
Fitting these as we speak - the original fittings seem to have to be replaced, in that the hose misses out the metal pipe on the back of the caliper and you have to screw it straight flush to the caliper on a banjo bolt. Anyone fitted these little beasties confirm thats how its done, just to be sure!
Hope you get it all sorted! I'm thinking about installing my HEL ones next weekend before a trackday but I don't want to attempt doing them if it goes tits up as you can't exactly drop it off at a garge for them to finish if you can't stop the car :lol:
Thanks Abbey/Mark/Scott ;)
Yeah I ended up doing that, lots of filing back and fiddling under the wheel arches, took about 30 mins per wheel in the end! I can't understand why HKS or HEL didnt just use screw in lines like OEM? (Goodridge seem to have screw in for 350z) I can't understand the thinking really, a screw in line would seal where its meant to seal inside the caliper :shrug: using the banjo bolts leaves the line open to leaking if the prep of the caliper doesn't seal fully.
Hmmm yeah I guess. Although wouldnt imagine it would be anything more than £5-£10 which you would recover in labour time if a garage were fitting them ;)
Worth noting if people are fitting these, you do need to really prep the caliper as most will have degraded to varying degrees. Also, on the front, you need to use P clips to secure the lines out the way of the tyres. As Abbey said, it is a lot to do if fitting for the first time so make sure to give yourself time and plenty of spare brake fluid :thumbs:
I had this very issue when i took my car to a local specialist while i was away with work. He was fitting a few things and doing a service for me. He refused to fit them in the end,as he deemed them unsafe,and a cheap design. I have had them fitted by Horsham Developments,and they have been fine,but understand now why the Goodridge ones are more expensive.
BulletMagnet: Thanks!, do you have any of the other end? its the first time ive changed brake lines.
coldel: Will do :thumbs: , Im planning to give the calipers a good clean up while I have them off the car
Sorry, I have not, DMS were too quick for me, haha.
But yeah, copper washers either side of the banjo bolt and job should be a good'un
BulletMagnet: Will do mate.
On a side note im looking to buy some flare nut spanners for this job, Im going to buy a set as im sure ill use them again on something else.
Ive found these on ebay:
http://www.ebay.co.uk/itm/BERGEN-7-Piec ... 415ca7b91f
They are 12 point in stead of hex, will i be taking a risk in rounding off the nuts or am i better off spening more and buying a hex kit?
Personally I'd go for hex, plus I have learnt over the years that when you buy tools, it's worth paying for quality tools.
Buy cheap, buy twice (or more)
And I doubt that flared spanners are gonna last long when encountering seized nuts & bolts.
Thanks, Ive taken your advice and gone for the Hex option.
Just about to start on the swap,
Ive read the workshop manual for procedure and it states the battery negative should be disconnected after the fluid has been drained.
Is it necessary?
No need to disconnect the battery terminal.
Best also not to drain the fluid as you may get an air lock which might be difficult to get rid of as a DIY project.
Alex. :)
