Ian Posted January 23, 2007 Share Posted January 23, 2007 Not sure where to post this, im probably in the wrong section Are the samco coolant hoses worth getting? Getting a few pieces done on friday & i can get the 4 coolant hoses for about £80. Is it worth it? Quote Link to comment Share on other sites More sharing options...
sl114 Posted January 23, 2007 Share Posted January 23, 2007 depends what you are after, IIRC its not worth it unless you are really doing up your engine or are making the engine bay look nicer. Quote Link to comment Share on other sites More sharing options...
Trev-the-Rev Posted January 23, 2007 Share Posted January 23, 2007 Like Louis says depends what you want. If you are after something that just looks better, then there are cheaper alternatives. But if you want improved performance in terms of life-span and pressure capacity then Samco are among the best imo. Quote Link to comment Share on other sites More sharing options...
Guest prescience Posted January 23, 2007 Share Posted January 23, 2007 Seem to recall there is an issue with these; I'll dig the post out Edit-> no, it was a communication I had with oilman but I cannot substantiate. So it's a proceed with caution Quote Link to comment Share on other sites More sharing options...
Ian Posted January 23, 2007 Author Share Posted January 23, 2007 Think ill leave these until I get a few other things in the engine bay done. Quote Link to comment Share on other sites More sharing options...
