Ian Posted January 11, 2012 Share Posted January 11, 2012 Sounds like the battery to me. I used to get the exact same symptoms when I had a dodgy battery Quote Link to comment Share on other sites More sharing options...
Stew Posted January 11, 2012 Share Posted January 11, 2012 I'd look at the car battery too. It does do the crazy tick when it's low. The engine is a big one to crank so if the battery isn't good it won't go. Quote Link to comment Share on other sites More sharing options...
mase9882002 Posted January 11, 2012 Author Share Posted January 11, 2012 Ian - I used to have a similar issue due to the battery not fitting in the compartment right which was resolved. At the time I used to have no electrics whatsoever once turning the key but with this its ticking over. Symptoms the same as me now with regard to battery? Cheers Dave Quote Link to comment Share on other sites More sharing options...
Ian Posted January 11, 2012 Share Posted January 11, 2012 How does the car tick over if it doesn't start? I stand by battery & I'll be amazed if its anything else tbh Quote Link to comment Share on other sites More sharing options...
Dblock Posted January 11, 2012 Share Posted January 11, 2012 How does the car tick over if it doesn't start? I stand by battery & I'll be amazed if its anything else tbh I think he means the car "ticks" when the start motor is moving? Quote Link to comment Share on other sites More sharing options...
Ian Posted January 11, 2012 Share Posted January 11, 2012 In that case ITS THE BATTERY!! Quote Link to comment Share on other sites More sharing options...
flyboy Posted January 11, 2012 Share Posted January 11, 2012 I read that as car turns over but wont start! WE need to know if its cranking or not! If its not then it does seem its the battery or starter. Quote Link to comment Share on other sites More sharing options...
Cragus Posted January 12, 2012 Share Posted January 12, 2012 1. Hook up a set of jump leads and try to start it. 2. Success! 3.Sign on the forum. 4. Tell everyone they were right. 5. Jobs a good un! Quote Link to comment Share on other sites More sharing options...
docwra Posted January 12, 2012 Share Posted January 12, 2012 Battery dial reading up at 12v when turned on, on its own, after turning more to click over, reading around 6-8. Thinking fuel pump myself but not heard about this much on Z's... 6-8 volts isnt enough to turn the engine. Guess what ........... ITS THE BATTERY! Quote Link to comment Share on other sites More sharing options...
