rm cya Posted January 9, 2012 Share Posted January 9, 2012 anyone stock them on here? or know where to get a decent set from? preferably hubcentric!! Quote Link to comment Share on other sites More sharing options...
rm cya Posted January 9, 2012 Author Share Posted January 9, 2012 anyone stock them on here? or know where to get a decent set from? preferably hubcentric!! Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted January 9, 2012 Share Posted January 9, 2012 MWTech do them 15mm 20mm 25mm 30mm and 35mm available usual combo is 20/25 or 20/20 let me know Quote Link to comment Share on other sites More sharing options...
rm cya Posted January 9, 2012 Author Share Posted January 9, 2012 perfect mate, pm sent! thought i had 25 on the rear, measured today when fitting the Eibach springs and its only 20mm. popped to halfrauds, picked up their 9.5mm spacers, but not comfortable with how they fit. put them on the inside of the eibach spacers, but not enough thread on the lugs for the spacer nuts. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted January 9, 2012 Share Posted January 9, 2012 perfect mate, pm sent! thought i had 25 on the rear, measured today when fitting the Eibach springs and its only 20mm. popped to halfrauds, picked up their 9.5mm spacers, but not comfortable with how they fit. put them on the inside of the eibach spacers, but not enough thread on the lugs for the spacer nuts. Spacer on a spacer ... that would make me clench MWTech will sort you out Quote Link to comment Share on other sites More sharing options...
rm cya Posted January 10, 2012 Author Share Posted January 10, 2012 Haha it's not that bad, torqued everything up and it's all fine, but would rather have just one plate fitted. Does anyone run 30mm spacers on the rear without arch work? Wondering now if I should just stick to 25s Quote Link to comment Share on other sites More sharing options...
rm cya Posted January 10, 2012 Author Share Posted January 10, 2012 Afterthought - what about running a bit of stretch on the stock rays? 30mm looks so good!! Quote Link to comment Share on other sites More sharing options...
Stew Posted January 10, 2012 Share Posted January 10, 2012 30mm spacer on the rear works fine with no suspension mods. Looks great too. Quote Link to comment Share on other sites More sharing options...
rm cya Posted January 10, 2012 Author Share Posted January 10, 2012 I've just fitted the eibach pro kit. Looks amazing but don't want to mess the arches up. Quote Link to comment Share on other sites More sharing options...
MWTech Posted January 15, 2012 Share Posted January 15, 2012 are you sorted out now? what size did you go for in the end? thanks for the kind recommendations fellas Quote Link to comment Share on other sites More sharing options...
rm cya Posted January 15, 2012 Author Share Posted January 15, 2012 Still undecided at the mo mate! I reckon I'm going to go 25s as it sits fairly low, and A- I don't want to do any arch work, B- don't want tyre to arch contact. But 30s look so good!!! FML!!! Quote Link to comment Share on other sites More sharing options...
agentsmith350 Posted January 16, 2012 Share Posted January 16, 2012 So on standard suspension you can definitely run 30mm on the rear ? What about the front ? Quote Link to comment Share on other sites More sharing options...
