engine malfunction light
The Accountant
Hi all
Had this light just come on, and followed steps on the forum to find the code..Does it repeat the code over & over & not stop? Managed to get the light flashing, not sure if I messed up but came back on after I switched off/on.
The code I think is
1slow 1fast 6fast 7fast
Thanks in advance
Ok thanks for the reply. :thumbs:
So its this? P1167 Heated O2 Sensor 2
Not one to worry about its fine to drive. Reset it using the procedure in the guides and see if it re appears..if it does then have a look at a new sensor. Are you decatted?
I have had the O2 sensors throw up a warning light about 4 times in my 6 yrs of ownership. The last time was only a few weeks ago. ECU was reset by the garage and not a peep since. I read the code myself but took it to the garage to confirm. Next time I will reset myself and save £35 and the hassle of going to a garage.
  • 3 months later...
A little more advice from the experts here would be a really appreciated. The first time this happened I had the garage reset it & check, but since it's come on 4 times in 3mths with the same code. Should I reset it again myself or take it to the garage to see if there's a problem?
I had the same issue although mine has Hi flow cats which can cause the ECU to put up the same error code, I fitted a new sensor as I got fed up with keep on resetting the ecu and hey presto no more error code so I would say one of your o2 sensors needs changing (about £90 from ZMANALEX)
