speedwell Posted December 21, 2011 Share Posted December 21, 2011 So,having disconnected my battery to re-charge it after it went flat (me stupidly leaving lights on),I got the car running again,but,because I did not read the instructions in the drivers manual, I lost the "window drop". So I went through the procedure in the manual and the driver side window now is OK but the passenger side has no "drop". Which got me thinking...should the passenger one be the same as the driver side,because I've not had the car long so cannot remember if it was always like it is now. On the other hand,if it is faulty,what do I do next?I've done a search and seen something about removing the door casing and doing a window re-set,is that next?Can anyone help? Quote Link to comment Share on other sites More sharing options...
bronzee Posted December 22, 2011 Share Posted December 22, 2011 So,having disconnected my battery to re-charge it after it went flat (me stupidly leaving lights on),I got the car running again,but,because I did not read the instructions in the drivers manual, I lost the "window drop".So I went through the procedure in the manual and the driver side window now is OK but the passenger side has no "drop". Which got me thinking...should the passenger one be the same as the driver side,because I've not had the car long so cannot remember if it was always like it is now. On the other hand,if it is faulty,what do I do next?I've done a search and seen something about removing the door casing and doing a window re-set,is that next?Can anyone help? Yes, they should both drop in unison about 5mm (in metric). Try doing a window reset first - do a search for that. Taking the door card off isn't hard though. Quote Link to comment Share on other sites More sharing options...
spursmaddave Posted December 22, 2011 Share Posted December 22, 2011 The passenger door card is a little trickier that the drivers side because of the hand rail but still not that hard with the right guide :wink: Quote Link to comment Share on other sites More sharing options...
speedwell Posted December 22, 2011 Author Share Posted December 22, 2011 OK,thanks,I've found the thread which shows how to remove the door cards,I'l do the re-set. ...and well done NZ for the recent win over the Aussies...if you're bothered about cricket Quote Link to comment Share on other sites More sharing options...
