sagey9 Posted December 19, 2011 Posted December 19, 2011 Dear forum, I have noticed over last few weeks that I am getting a lot of condensation/damp inside rear window that is not clearing with demister even after running car for 10 mins warm. Am thinking window seals may have gone as it should be dry, or the demister is not working. I dont drive the car that much (once a week generally, but go on long trips quite often) so possibly it just needs a good airing!! however surely it should be dry inside even if parked up for long periods... Has anyone else had this issue? Got it booked in Wessex Bristol to check it out on Thursday but may cancel if anyone thinks this is normal this time of the year... Thanks... Quote
dragon Posted December 19, 2011 Posted December 19, 2011 yeah mate get the seals checked even a tiny amount of leakage over time will do that !! Quote
Ken Posted December 19, 2011 Posted December 19, 2011 Check the the bottom corners think that's the place water gets in. Quote
ChrisS Posted December 19, 2011 Posted December 19, 2011 Most 350s have a condensation problems. Run the air con all the time,it removes moisture and helps defrosting. Quote
ATTAK Z Posted December 19, 2011 Posted December 19, 2011 Most 350s have a condensation problems. Run the air con all the time,it removes moisture and helps defrosting. Chris is correct .... common problem .... AC is not just for hot weather ... run it 24/7 Quote
DoogyRev Posted December 19, 2011 Posted December 19, 2011 Most 350s have a condensation problems. Run the air con all the time,it removes moisture and helps defrosting. Chris is correct .... common problem .... AC is not just for hot weather ... run it 24/7 +1 Welcome to the Forum Quote
spursmaddave Posted December 20, 2011 Posted December 20, 2011 Completely normal, sometimes even with the air con on and rear heater mine mists up a little.... Quote
jumping350 Posted December 20, 2011 Posted December 20, 2011 seems normal to me buddy i dont use aircon at all just open the windows and mess with the heaters goes away after little bit...if its still there then yes probably your seals Quote
sagey9 Posted December 20, 2011 Author Posted December 20, 2011 ok cheers for your help may save the cash and not take it in - seals going on an 08 reg does seem a little premature... Thanks for welcoming me to the forum Quote
Dblock Posted December 21, 2011 Posted December 21, 2011 Sounds like as you said its the demister isnt working. If the window is heated even if its wet in the car you shouldnt get steam on it. Check the fuse It might be your seals aswell though but there will always be moisture in your car. I use Silca gel that you get with a sofa (big things) and have them in my car to suck up some moisture when its cold. I then leave them on the radiator to get rid of the water. Works really well actually. Quote
