chocohercules Posted December 14, 2011 Share Posted December 14, 2011 Hi Guys Can someone tell me where the Knock Sensor is located with possible pics? Is it easy to locate and get to? Cheers Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted December 14, 2011 Share Posted December 14, 2011 Under the lower plenum , not a nice job to get to. remove upper and lower plenum and manifold to get to the knock sensor. If the motor is out you can get to the sensor without stripping all the stuff of but you wont be able to torque the knock senor retaining bolt without removing all the above parts. Whats the problem with the car? Quote Link to comment Share on other sites More sharing options...
chocohercules Posted December 14, 2011 Author Share Posted December 14, 2011 Thanks for the reply ab. Well engine light is on, had a service done so not spark plugs, air filter! Car is running ok no missfire symptoms but feels really sluggish, no pull at low revs and feels rough! Had a search on the forum and sounds like other people have had the trouble and pointed towards knock sensor?? Quote Link to comment Share on other sites More sharing options...
Dblock Posted December 14, 2011 Share Posted December 14, 2011 chocohercules said: Thanks for the reply ab. Well engine light is on, had a service done so not spark plugs, air filter! Car is running ok no missfire symptoms but feels really sluggish, no pull at low revs and feels rough! Had a search on the forum and sounds like other people have had the trouble and pointed towards knock sensor?? Have you read the code? Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted December 15, 2011 Share Posted December 15, 2011 Yes you need to read the code , I not seen a car with a knock sensor fault yet but there is always a 1st time thou. Mark Quote Link to comment Share on other sites More sharing options...
chocohercules Posted December 15, 2011 Author Share Posted December 15, 2011 (UPDATE) Hi guys thanks for the info! I have had the code reading: P0335 CKP Sensor Circuit Problem! Any ideas? its some sort of Sensor where is it located? Cost? and is it easy to get to and replace? Cheers Quote Link to comment Share on other sites More sharing options...
Mark@Abbey m/s Posted December 15, 2011 Share Posted December 15, 2011 crank angle sensor it is the gearbox/engine joint under the car passengers side. easy job to remove and clean 1st to see if it cures the problem; Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted December 15, 2011 Share Posted December 15, 2011 chocohercules said: (UPDATE) Hi guys thanks for the info! I have had the code reading: P0335 CKP Sensor Circuit Problem! Any ideas? its some sort of Sensor where is it located? Cost? and is it easy to get to and replace? Cheers That will be your crank position sensor. Quote Link to comment Share on other sites More sharing options...
chocohercules Posted December 15, 2011 Author Share Posted December 15, 2011 Thanks for the info guys will try and clean it first and erase the code! Quote Link to comment Share on other sites More sharing options...
chocohercules Posted December 19, 2011 Author Share Posted December 19, 2011 Update! i have located the crank position sensor cleaned it, but light remains even after trying to erase the code. Cell goes off then once engine is turned off and re-started cell comes back on. Going to buy a new sensor from the dealer on the weekend. could an aftermarket clutch affect the sensor as i had one fitted which isnt a dual mass jobby, was just reading up on afew threads............. More codes I was told the Crank Position Sensor was causing my ABS and ESP (traction control) lights to come on? is this true? C1130 Engine 1 Fuel Cut System Fault C1103 R Front Wheel Sensor Circuit Open/Short Thanks for any info guys Quote Link to comment Share on other sites More sharing options...
Neilp Posted December 19, 2011 Share Posted December 19, 2011 Why the dealer? I'm pretty sure Alex can get them much cheaper. Last week Nissan wanted over 250 for a water pump and Alex had genuine ones at 50. Drop him a message mate. Quote Link to comment Share on other sites More sharing options...
DoogyRev Posted December 19, 2011 Share Posted December 19, 2011 Neilp said: Why the dealer? I'm pretty sure Alex can get them much cheaper. Last week Nissan wanted over 250 for a water pump and Alex had genuine ones at 50. Drop him a message mate. +10000000000000 Quote Link to comment Share on other sites More sharing options...
