oil pressure and suggested brands
Shinjuku
Please don't use Magnatec, it really is the devil's arsehole when it comes to oils. It'll go thin as anything when warm and will do nothing for your engine's protection. Top it up if you must, but then I'd be looking at doing a full change with something decent fairly quickly (sub 1000 miles at least).
Magnatec is about as much use as pouring cat **** into your engine. 0w40 is a bit thin IMHO and you'll probably get the same issues, I'd go with one of the other recommended oils on this page.
quick search found this many others are not fans either say its to thin and can burn off and escape to easily and a thicker oil is better
