Missfire / jumping
Sam350z
Hi just become a member. I'm having missfire problems/ jumping when engine warming up. It's a 58 plate. The dealer has had it in three times and can't find what the problem is, no management light illuminated. Has anyone had this prob before, I'm thinking it could be a coil breaking down. :band:
:( Had the car at RS Tuning. Still got the problem. They say that the exhaust cam is moving when it shouldn't be, don't now why. If you unplug the electrics to the cams problem goes away. Checked all the earths etc. Spoke direct to Nissan who say take it to the dealer, so I,m going to try adiffferent one. Anybody had any experience with Evans Halshaw in Leeds ? :bang:
Sam,
ask on here if there is any local HR owners if they will lend you there ECU take it to RS they can load a map in the ECU to turn the NATS off ( using UPREV) and try the car with another ECU this will remove 1 possible problem.
I have spoken to RS today about your car and it does seem strange that the exhaust cam is causing the problem thou , I am sure it is sortable but may take a little time to sort.
Thanks for the information. Just been having a look on the web found an article that describes what my engine is doing. The crank position sensor could be faulty and not giving the correct information. Would it be better to try this before trying another ECU ? :cry:
I had this problem on one of my cars - turned out to be the crank sensor. Symptoms were intermittent misfiring, no fault codes logged. When it missed the rev counter would jump about a lot. I stuck an oscilloscope on the output to confirm a dodgy signal. Ended up just cleaning the sensor and mounting face and it was fine since. This was on an 2004 car, so VQ35DE, your 350 will have the VQ35HR engine but I'd imagine it'll use the same sensor.
  • 1 month later...
Problem solved. It wasn't the cam position sensor it would appear that the Nissan dealer has been putting the wrong oil in when servicing the car. I took my own last time, Castrol Edge 5W30 and problem has gone. It's like a new car the same as when I first bought it. They must have been putting the incorrect oil in from the first 9000 mile service. So only had to endure the problem for 72,000 miles. :bang:
