Engine management light flashes, any ideas?
L4V15
Hi there. This evening I was driving and the engine management light started flashing, at low engine speeds more so. I first noticed that it sounded like it was running really rough, then noticed the light flashing. It then went away for a good 5-10 minutes and then briefly did it again for another minute or so. Then went again for 10minutes. Havent been in the car again since but I have a 200mile drive to do tomorrow so wondering whether it will be ok? Does anybody have any sort of diagnoses for this? Cat converters? They seem to look and sound fine. Just had a full service last week aswell. Sounds really rough only when the light starts flashing, almost like a subaru boxer engine or something. Think it losses power aswell but was totally fine and sounding fine after the light went away.
Anyway im rambling. Somebody please help.
Cheers
Steve
if its going lumpy and sounds like a boxewr engine it sounds like 1 or more cyclinders isn't working, either a missfire, could be a spark issue, or it could be a fuelling issue; maybe a blocked injector.
but it needs the code pulling.
also as said above, light on means need checking but not critical. flashing means you should pull over as soon as possible to avoid engine damage.
personally i wouldn't be taking that car anywhere other than to the garage.
Hmm. I had no option. Has been totally fine since though. Do.you think.it could have been a temporarily blocked injector maybe then? Havent had any warning lights and sounds normal now. Also it was very wet when it happened? Don't suppose that could effect anything? Thanks for the responses
without knowing your car, wahts fitted etc, any mods, its like a blind man trying to score a hole in one form 500 yards after being spun round 50 times first.
