dgrooky Posted December 8, 2011 Share Posted December 8, 2011 on the way home from work tonight,heard an intermittant whistling sound first thought it was dirt on the brake discs.then when the car was stationary the sound was still present ,any idea what this is ? do any of the belts make this noise?.its a 370 with only 7000mls. Quote Link to comment Share on other sites More sharing options...
geoff-r Posted December 9, 2011 Share Posted December 9, 2011 Get it down the dealers if you're not sure mate Mine has just under 7k but no such noise like that. Quote Link to comment Share on other sites More sharing options...
dgrooky Posted December 9, 2011 Author Share Posted December 9, 2011 cheers mate,take her out for a run tomor see if i cun pin point it then book her in.first little hiccup other than that no problems with a nissan .wont be taken it back to wessex nissan tho. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 10, 2011 Share Posted December 10, 2011 Not heard that before. When does it happen? Happening when stationary would suggest to me that an air feed pipe or plenum could be loose. Does it get louder when you give it some throttle? As Geoff says get it back to the dealer, should be an easy fix. Quote Link to comment Share on other sites More sharing options...
dgrooky Posted December 11, 2011 Author Share Posted December 11, 2011 hi there chris,took her out today for a good run and nothing,no it didnt get louder when revd up take her out again tomorow ,if it happens again ill take her straight in to be checked,and make a post to say what is found. Quote Link to comment Share on other sites More sharing options...
Chris`I Posted December 11, 2011 Share Posted December 11, 2011 Strange one, think I'd get it to the dealer when you can just to be sure Quote Link to comment Share on other sites More sharing options...
